Print at Jul 22, 2026, 9:02:48 PM
Posts: 27   Pages: 3   [ Previous Page | 1 2 3 ]
Posted by Mike53 at Nov 4, 2018, 6:19:43 PM
Re: Cut out
You may need to disable magnetism while positioning them.
Posted by stef.salmon at Nov 4, 2018, 6:25:15 PM
Re: Cut out
Hi Mike,
If I disable magnetism I can line up the door, but it doesn't cutout the invisible box like it does on a normal wall.
Posted by Puybaret at Nov 4, 2018, 6:33:27 PM
Re: Cut out
Invisible boxes don't cut other pieces of furniture. They only cut walls and floors as show in this tip.
Posted by stef.salmon at Nov 4, 2018, 6:47:08 PM
Re: Cut out
Is there a way of having a transparent wall with a door?
I have managed to put in some transparent glass walls, but now I just need to add a door which actually has a cutout.
https://www.dropbox.com/s/ec2gvrl4mr89688/KWS_SS.png?dl=0
Posted by Mike53 at Nov 4, 2018, 7:11:28 PM
Re: Cut out
Not sure i understand correctly, but have you thought to insert the door into a wall with its opacity set to nearly clear, then exporting both the door and the wall?
Posted by stef.salmon at Nov 4, 2018, 7:49:01 PM
Re: Cut out
Never tried to create an object before!
That worked a treat...thanks Mike wink
Posted by Mike53 at Nov 4, 2018, 7:55:15 PM
Re: Cut out
Thank the lord its nearly january, i only get 1 good idea a year. biggrin
