Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Include light source in a furniture or group light source and item |
| Print at Jul 22, 2026, 8:20:37 PM | |
| Posted by Cactus at Feb 11, 2011, 2:20:17 PM |
Include light source in a furniture or group light source and item Hello, I'd like to include light source in some of my furnitures. For example I created a lamp but when I add it in my room and create a photo it does not make any light. So I added a light source inside and it's ok. But know when I want to move my lamp I have to select the lamp + the light source. It's not very complicated but as I have a lot of lamps and I move everything all the time, it's a bit anoying. I'd like to group the lamp and the source into a single object. I tried the "group" command but it does not work. I managed to do it with simple objects but it looks like it does not work with light sources. Other solution would be to edit my .obj object but I'm not sure adding a light source in an object is as simple as adding a color or a mirror. I found a lot of usefull information in the forum and in the documentation about lights but I didn't manage to solve this problem. |
| Posted by hansmex at Feb 11, 2011, 2:57:36 PM |
Re: Include light source in a furniture or group light source and item Cactus, Well, it definitely works. Move the light to the side, group it, and try again. Now, the solution to your problem. When the light bulb is hidden or obstructed by the lamp, the light can't get out. So, make sure that lamp and light don't interfere. Also, most lamp shades aren't transparent, so that too will obstruct (or at least reduce) the light getting out. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by Cactus at Feb 11, 2011, 3:35:06 PM |
Re: Include light source in a furniture or group light source and item Thanks for the quick reply. The problem is not with the final result on the picture. If I put my lamp with a light source inside, the result is ok and the light is fine on the final picture. Light gets out of the lamp properly. As you told me that it's supposed to work I tried again in different ways and finaly managed to do it and found what I did wrong: If I click the source, press shift, click the lamp and then group it works. If I select both by clicking besides and maintain click (like drawing a square) and then group it doesn't work. What is strange is that I don't have this problem with all the light sources. I don't know if my explaination is very clear... but at least it finaly worked. Thanks ! |
| Posted by wrosun at Feb 11, 2011, 4:55:48 PM |
Re: Include light source in a furniture or group light source and item if you cannot select the lamp and the light source together in the 2d plan then you can use the list on the left hand side of your screen which shows which objects you have used......then you can use group furniture command or simply go with ctrl+G.... |
| Posted by wrosun at Feb 12, 2011, 6:24:52 PM |
Re: Include light source in a furniture or group light source and item Correction: sorry for the error!! its ctrl+Shift+G |
| Posted by Cactus at Feb 14, 2011, 4:36:42 PM |
Re: Include light source in a furniture or group light source and item Yes I found the different ways to group objetcs. The thing is for this special case only one way of selecting the items didn't allow me to group them. As it was the first time I used light sources I thought it was because light sources could not be groupped but actually it has nothing to do with it. Your way of selecting items works too, thanks. |
| Posted by 3dfx at Feb 14, 2011, 10:26:21 PM |
Re: Include light source in a furniture or group light source and item Some related questions: I've created a simple model of a lamp with translucent white glass using Sketchup. The lamp is cylinder shaped with an open top. The model was then exported to .dae and imported to SH3D 3.1. When I place a light source within the lamp the light and render a photo (at highest quality) the light only seem to escape through the top and not through the glass. The lamp model looks correct in the preview mode as shown in this screenshot: http://img143.imageshack.us/img143/1030/sh3dlightsscreenshoot.png. Any idea what mistake I could have made? I also have a more general question on the "customized lamps topic".. Is it possible to create custom light sources that could be included as a lights in SH3D? (I'm thinking of modeling a couple of LED spotlights so I'd like to be able to set color temperature, light distribution angle, direction as well as model the armature). |
| Posted by hansmex at Feb 14, 2011, 11:36:24 PM |
Re: Include light source in a furniture or group light source and item 3dfx, SH3D provides excellent light handling on the control and output side, but on the creation side things could do with some improvement. To answer your first question: 1 - export your DAE lamp to OBJ format, and an OBJ and MTL file will be created; 2 - download this document that describes in some detail the properties of a MTL file; 3 - edit the MTL file with a text editor; 4 - search for the part that describes the shade and light source, then manually edit their properties and make sure there is an illum and d statement with the proper values (see page 6); 5 - hope that this solves your problem. The solution to your second question will probably involve programming a plug-in or extension that will allow you to set those variables. The SH3D source code is available on SourceForge, but as I cannot program, I wouldn't know exactly where to find it. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by 3dfx at Feb 15, 2011, 11:07:29 PM |
Re: Include light source in a furniture or group light source and item Thank you Hans! I exported the sketchup model to obj using TIGs OBJExporter script. The default material definition was: newmtl Translucent_Glass_White15 Ka 0.000000 0.000000 0.000000 Kd 0.996078 0.996078 0.976471 Ks 0.000000 0.000000 0.000000 d 0.750000 map_Kd my-cylinder-lamp_Textures/Translucent_Glass_White15.jpg I tried to change the values but could not get the effect that I'm looking for (frosted white glass). With the map_Kd param I have no transparency in the result Create Photo dialog. If I remove the map_Kd param and add some Illum I get a colorless translucent shape from Create Photo. The strange thing is that the preview seems to handle the settings better, e.g if I set Ks 0.000000 1.000000 0.000000 I get a translucent green lamp in the preview whereas the rendered photo only gets color reflected upon it. |
| Posted by hansmex at Feb 16, 2011, 12:16:52 AM |
Re: Include light source in a furniture or group light source and item 3dfx, The fact that I assembled the OBJ properties document doesn't mean that I understand how to use it... I've dabbled a bit with it, but the best (and only) thing I managed to do was making an object invisible. After that my curiosity disappeared... Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by 3dfx at Feb 16, 2011, 6:52:59 PM |
Re: Include light source in a furniture or group light source and item Hans, the docs were helpful and now I can get transparent glass instead of a solid texture but I want something in between I think there might be an answer in PhotoRenderer.java but I'm still to find it.. |
| Posted by hansmex at Feb 16, 2011, 7:37:27 PM |
Re: Include light source in a furniture or group light source and item 3dfx, Have you read this link? Or this one? And this one? And of course this one... Maybe this is relevant? Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by 3dfx at Feb 16, 2011, 9:12:54 PM |
Re: Include light source in a furniture or group light source and item thanks again! I had seen some of the threads before. I've now read all threads, did not understand everything but it seems to me that it's not possible to do transparent frosted glass in sh3d. |
| Posted by hansmex at Feb 16, 2011, 10:44:34 PM |
Re: Include light source in a furniture or group light source and item 3dfx, Somewhere in the back of my head, I seem to remember that Whippetsleek has been experimenting with glass, using Sketchup, multiple layers and adaptation of MTL files... Rather complex stuff. You might try to find those posts on the forum. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Jul 22, 2026, 8:20:37 PM |
