Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Generate roof plugin |
| Print at Sep 10, 2026, 10:17:19 PM |
| Posted by Indigo_Solo at Nov 17, 2025, 1:27:40 PM |
Re: Generate roof plugin Hello! I finally have taken the time to test this plugin, And here is my humble opinion: It is amazing! As you've seen, I spent days building the roof parts that work as a pieces of LEGO to build roofs. But, this plugin, summarizes it in few seconds, overcoming the troubles of making roofs in the traditional way (building and rotating triangles). That's why I built the parts... I know absolutely nothing about programming. Roof Generating plugin just amazed me. It doesn't leave tips of roof inside. Textures are set properly in all faces (tiles drain water to down). You can personalize the roof. The base (ceiling of the attic) could be generated as well, if you copy and then paste the roof and then set the copy below, with proper modifications. And, If don't matter, I'll tell you what would make it perfect (I've just try): If square or even round holes could be opened in parts of the roof. It could be set in one of two ways: 1. In the dialog of the plugin, before the roof generation. 2. Making the roof object, once generated, to act as a room when a stair is inserted, or a wall when a door or window is inserted. This could allow the creation of everything else: Dormers, chimneys, monitor roofs, skylights, vents... Congratulations. This has been a dream plugin. I'll give one of my hands to know programming and cooperate instead of only suggest. Have a nice day, and thank you so much for your work! ![]() |
| Posted by Keet at Nov 17, 2025, 2:12:00 PM |
Re: Generate roof plugin And, If don't matter, I'll tell you what would make it perfect (I've just try): I don't know about round holes but Dorin created the possibility to add special windows into the roof. Indeed one of the very best plugins!If square or even round holes could be opened in parts of the roof. Check this post and the latest versions on sourceforge . ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by Daniels118 at Nov 17, 2025, 4:10:06 PM |
Re: Generate roof plugin You need both hands to write code faster! No need to give away body parts, just time to learn and try. You can obtain rectangular holes using the roof window library. Then if you need just the hole for a stair, you can make the window invisible. |
| Posted by dorin at Nov 17, 2025, 8:52:06 PM |
Re: Generate roof plugin Welcome aboard! While you're already here don't hurt to read the entire tread from start. I have written several user manuals (outdated) but still valid. 0. All the awards have to go to Daniels118 and Emmanuel. I know absolutely nothing about programming. I'm not either. 1. Keep your hand and fingers safe; you will need them. 2. Be carefully, a dream could easy became a nightmare. The last version is a nightmare for me and I'm a nightmare for Daniels118. 3. Nothing is perfect! (Not even God, look at the world created in seven days). I've never tried round holes but half round. (See this post ) or Roof dormers tutorial . If you need help just ask. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
| Posted by dorin at Feb 25, 2026, 8:12:59 PM |
Re: Generate roof plugin "A small step for the plugin, a big step for me." I've manage to make SitePlane to work with java3D. ![]() Now I need to learn how and why it works. Then, how to use it for the existing plugin without breaking it. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
| Posted by dorin at Mar 6, 2026, 11:20:17 AM |
Re: Generate roof plugin Version 5.2 News: - Correcting the elevation of roof windows when the height of the roof has been previously modified in the plan. - Replace the invisible checkbox function with the corresponding closed eye for each face in the list. - Add a right-click context menu to the list of faces. - Rewrite the Axes class. Now they automatically adapt to the roof and are 1 m longer. - Add support for grouped roof windows. ![]() ![]() Also on Source Forge . ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
| Posted by Xlance at Mar 11, 2026, 7:28:57 PM |
Re: Generate roof plugin Can we use the new Boolean plugin to subtract holes in generated roofs ? Consequently adding any window from standard library. ---------------------------------------- Windows 64bit | Intel i7 | 8GB Ram | SH3D 7.5 + Plugins |
| Posted by Keet at Mar 11, 2026, 8:46:47 PM |
Re: Generate roof plugin You can do that now. But... The resulting roof will no longer have separate material names and it can't be re-imported in the Roof Generator. You will have to repeat the boolean difference operation for each window. That said, the calculation behind the boolean difference option could possibly be integrated in the Roof Generator plugin and create the holes without changing the rest of the roof. I don't know if this is possible. Dorin will know more about that since he knows both plugins. Using regular windows is problematic in itself: you can't tilt regular windows. You will have to export them, import as normal furniture, tilt, export, and import again as door-or-window. Extra library properties like sashes and wall distance will be lost and opening the windows could be affected too. Regular windows are not what you usually see in sloped roof. What would be absolute perfect is if the roof could act like a wall where a window snaps into the roof like it does in a wall. Makes it real easy to add windows and change its position. No need to cut a hole before placing the window. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by dorin at Mar 12, 2026, 8:17:18 PM |
Re: Generate roof plugin @Xlance Keet is correct. You will lose all the properties specific to roof and window objects. On the other hand, the MBC plugin is far from acceptable, mainly because of the texture, but also because some results have missing facets. @Keet To install roof windows in a roof, you still don't need to make holes; they make their own. I explained this in the user manual. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
Current timezone is GMT Sep 10, 2026, 10:17:19 PM |
