Print at Sep 6, 2026, 5:19:57 AM View all posts in this thread on one page
Posted by dorin at Sep 29, 2020, 8:09:26 PM
Distribute elevation plugin
I've rewrite it from scratch (almost stoled).
The previously Paste special & distribute plugin are no longer maintained but are replaced by two separate plugins.
This one are Distribute Elevation plugin v1 .
Is accessible under Furniture->Distribute elevation or an icon on toolbar.
IMHO I think this plugin must be replaced by an missing option in main SH3D.
How it work and what use for:
Let say we have some stairs...
but is not quite what we want;
we know the maxim high and don't want to make more precise calculations so:
-select and elevate the last step to maximum high...
-select all stair steps and:
-this could be the result.
Are more close to what we call staircase.
RECOMMENDATION:
Remove PasteSpecialDistribute plugin.
While I'm not a programmer use it with care!
Posted by dorin at Apr 5, 2024, 8:11:14 PM
Re: Distribute elevation plugin
New version 1.1
Reminder:
This plugin distribute selected furniture at equal elevation interval.
You will find it under Furniture (or corresponding translation) menu
and an icon on the tools bar.
News in this version:
1. For users:
-add the possibility to work inside furniture groups.
That mean if you modify the elevation in a group of furniture (eventually generated with Multiplier plugin)
and select this group, this plugin will modify the pieces elevation inside the group.
The minimum of 3 pieces number remains as mandatory.
-add Italian, German and Chinese translations (DeepL translator).
2. For developers and translators:
Now if you switch the language the plugin will be translated without need to restart the application (thanks to Emmanuel).
I've added pre-made files for all localization present in SH3D (18 files).
A potentially translator (who want to modify or to make a new one) will find them under locales folder inside the plugin, initially in English.
Their name looks like this: pkgDE_de.properties for German.
What that means?
-pkgDE=pkg+DE (DE=acronym for Distribute Elevation)
-_de= the localization indicator (German in this case)
-.properties= the file extension
I intend to do this to all my plugins but with their specific acronym (or closer):
SHU= Select Hide Utility
RR= Regular Room
GR= Generate Roof
and so on.
So, a translator could send me multiple files with the translation for different plugins at once.
I also intend to use it as a template for all my plugins. I'm still thinking about it wile is not as good as I wish.
That's all!
Also on Source Forge
