Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Distribute elevation plugin |
| Print at Sep 6, 2026, 5:28:59 AM | |
| Posted by dorin at Sep 29, 2020, 8:09:26 PM |
Distribute elevation plugin I've rewrite it from scratch (almost stoled). The previously Paste special & distribute plugin are no longer maintained but are replaced by two separate plugins. This one are Distribute Elevation plugin v1 . Is accessible under Furniture->Distribute elevation or an icon on toolbar. IMHO I think this plugin must be replaced by an missing option in main SH3D. How it work and what use for: Let say we have some stairs... ![]() but is not quite what we want; we know the maxim high and don't want to make more precise calculations so: -select and elevate the last step to maximum high... ![]() -select all stair steps and: -this could be the result. ![]() Are more close to what we call staircase. RECOMMENDATION: Remove PasteSpecialDistribute plugin. While I'm not a programmer use it with care! ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
| Posted by dorin at Apr 5, 2024, 8:11:14 PM |
Re: Distribute elevation plugin New version 1.1 Reminder: This plugin distribute selected furniture at equal elevation interval. You will find it under Furniture (or corresponding translation) menu and an icon on the tools bar. News in this version: 1. For users: -add the possibility to work inside furniture groups. That mean if you modify the elevation in a group of furniture (eventually generated with Multiplier plugin) and select this group, this plugin will modify the pieces elevation inside the group. The minimum of 3 pieces number remains as mandatory. -add Italian, German and Chinese translations (DeepL translator). 2. For developers and translators: Now if you switch the language the plugin will be translated without need to restart the application (thanks to Emmanuel). I've added pre-made files for all localization present in SH3D (18 files). A potentially translator (who want to modify or to make a new one) will find them under locales folder inside the plugin, initially in English. Their name looks like this: pkgDE_de.properties for German. What that means? -pkgDE=pkg+DE (DE=acronym for Distribute Elevation) -_de= the localization indicator (German in this case) -.properties= the file extension I intend to do this to all my plugins but with their specific acronym (or closer): SHU= Select Hide Utility RR= Regular Room GR= Generate Roof and so on. So, a translator could send me multiple files with the translation for different plugins at once. I also intend to use it as a template for all my plugins. I'm still thinking about it wile is not as good as I wish. That's all! Also on Source Forge ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
Current timezone is GMT Sep 6, 2026, 5:28:59 AM |
