Skip to content
The following table presents the full list of keyboard shortcuts and mouse actions that you can use in Sweet Home 3D (also available in a PDF file in English or in French).
ActionMenu itemIconKeyboard shortcutsMouse actions
WindowsLinuxMac OS XWindowsLinuxMac OS X
FILE
Open a new homeFile > NewCtrl Ncmd N
Open a previously saved homeFile > Open…Ctrl Ocmd O
Save the edited homeFile > SaveCtrl Scmd S
Save the edited home under an other nameFile > Save as…Ctrl Shift Scmd shift S
Save the edited home in a compressed file with same qualityFile > Save and compressCtrl Alt Scmd alt S
Close the edited homeFile > CloseAlt F4cmd W
Display Page setup paneFile > Page setup…Ctrl Shift Pcmd shift P
Print the edited homeFile > Print…Ctrl Pcmd P
Display Preferences paneFile > Preferences…
(Sweet Home 3D > Preferences… under Mac OS X)
Ctrl Mcmd ,
EDIT
Transfer the focus to a pane (pane surrounded by a colored rectangle receiving keyboard inputs)  Tab or Shift + TabClick in the pane
Undo the last actionEdit > UndoCtrl Zcmd Z
Redo the last undone actionEdit > RedoCtrl Ycmd shift Z
Copy and delete the items selected in homeEdit > CutCtrl Xcmd X
Copy the selected items in clipboard (+ a text of the selected furniture when the furniture list has focus, or an image of the selected items when the plan has focus)Edit > CopyCtrl Ccmd C
Paste the copied or cut items into homeEdit > PasteCtrl Vcmd V
Paste the copied or cut piece into the group selected in homeEdit > Paste to groupCtrl Shift Vcmd shift V
Paste the style of the copied or cut item to the selected ones (the copied and selected items must be of the same type)Edit > Paste styleCtrl Alt Vcmd alt V
Delete the selected itemsEdit > DeleteDelBack space
Select all items in the furniture list or the planEdit > Select allCtrl Acmd A
FURNITURE
Select a piece in furniture catalog or furniture list  Arrows ←↑↓→Click on the piece
Select contiguous pieces in furniture catalog or furniture list  Shift Arrows ←↑↓→Shift + Click on the last piece
Sort furniture listFurniture > Sort by > Column Click once on column header for ascending sort, twice for descending sort
Toggle the selection of a piece in furniture catalog or furniture list   Ctrl + Clickcmd + Click
Add the piece selected in the catalog to the plan at (0,0)Furniture > Add to homeCtrl Shift Fcmd shift FDrag and drop piece in furniture list
Add a piece of the catalog anywhere in the plan   Drag and drop catalog piece in the plan
Display the modification pane of the selected pieces of furnitureFurniture > Modify…Ctrl Ecmd EDouble-click on a piece
Create a group from selected piecesFurniture > GroupCtrl Shift Gcmd shift G
Ungroup all the pieces of the selected groupsFurniture > UngroupCtrl Shift Ucmd shift U
Align side by side selected pieces of furnitureFurniture > Align side by sideCtrl Shift Bcmd shift B
Reset the elevation of selected pieces according to their environmentFurniture > Reset elevationCtrl Shift Ycmd shift Y
Display the wizard used to import a 3D model as a piece of furniture (at second step, use Shift key to rotate degree by degree the 3D model)Furniture > Import furniture…Ctrl Shift Icmd shift IDrag and drop a OBJ, 3DS, DAE, KMZ or ZIP file onto catalog, furniture list or plan
Display the wizard used to import an image as a texture (at first step, a BMP, JPEG, GIF or PNG file can be dragged onto wizard)Furniture > Import texture…Ctrl Alt Icmd alt I
PLAN
Switch to the Select modePlan > SelectCtrl Lcmd L
Select the foremost item under mouse cursor   Click on item (in Select mode)
Toggle the selection of the foremost item under mouse cursor   Shift + Click on item
Select items intersecting a selection rectangle   Press mouse button over no item and drag mouse over items
Toggle the selection of items intersecting a selection rectangle   Shift + Press mouse button and drag mouse over items
Select an item under mouse cursor (including hidden items)   Right click + choose item in Select object submenu
Toggle the selection of an item under mouse cursor   Shift + Right click + choose item in Toggle selection submenu
Move selected items pixel by pixel  Arrows ←↑↓→Drag and drop selected items
Move selected items 10 pixels by 10 pixels  Shift Arrows ←↑↓→
Move selected items along horizontal or vertical plan axis   Drag selected items, pressing the Shift key after the first mouse move
Duplicate selected items   Ctrl + Drag and drop selected itemsalt + Drag and drop selection
Duplicate selected items along horizontal or vertical plan axis   Ctrl + Shift + Drag and drop selected itemsalt + shift + Drag and drop
Toogle temporarily magnetism set in preferences while moving the selected item   Alt while draggingShift Alt while draggingcmd while dragging
Switch to the Pan modePlan > PanCtrl Alt Pcmd alt P
Pan in the plan in Pan mode   Drag and drop mouse
Pan in the plan in other modes   Space + Drag and drop mouse
Pan up and down in the plan  Page up ⇞ / Page down ⇟Mouse wheelSwipe trackpad
Pan left and right in the plan  Ctrl ⇞ / ⇟ Shift + Mouse wheel
Zoom in plan and pan to show selected itemsPlan > Zoom inCtrl KCtrl +cmd +
Zoom outPlan > Zoom outCtrl Shift KCtrl –cmd –
Zoom in or out centered on mouse cursor   Ctrl + Mouse wheelcmd + Wheel
Lock the base plan (preventing the selection of base plan items)Plan > Lock base planCtrl Alt Lcmd alt L
Unlock the base plan (when the base plan is locked)Plan > Unlock base planCtrl Alt Lcmd alt L
Force the scale line to be horizontal or vertical during the second step of Import backgroung image wizard   Press Shift while dragging scale line ends
WALL
Switch to the Create walls modePlan > Create wallsCtrl Shift Wcmd shift W
Draw a wall and subsequent walls (in Create walls mode)   Click at wall start then at each wall end
Curve currently drawn wall (in Create walls mode)   Ctrl + Click + Choose angle with mouse + Clickalt + Click + Choose angle + Click
Enter wall dimensions with the keyboard (in Create wallsmode)  Enter
End drawing walls (in Create walls mode)  Esc / Double Enter in keyboard modeDouble-click at last wall end
Create missing walls around a room (in Create wallsmode)   Double-click in a room
Display the modification pane of the selected wallsPlan > Modify walls…Ctrl Shift Ecmd shift EDouble-click on a wall
Join the closest free ends of the selected wallsPlan > Join wallsCtrl Alt Jcmd alt J
ROOM
Select Create rooms modePlan > Create roomsCtrl Shift Rcmd shift R
Draw a room (in Create rooms mode)   Click at each corner of the room
Enter room dimensions with the keyboard (in Create rooms mode)  Enter
End drawing a room (in Create rooms mode)  Esc / Double Enter in keyboard modeDouble-click at the last corner
Create a room surrounded by walls (in Create roomsmode)   Double-click inside a closed surface
Display the modification pane of the selected roomsPlan > Modify rooms…Ctrl Alt Ecmd alt EDouble-click on a room
Add a point to an existing room   Right click on room border + select Add point to roommenu item
Delete a point from an existing room   Right click on room point + select Delete point from roommenu item
POLYLINE
Switch to the Create polylines modePlan > Create polylinesCtrl Shift Jcmd shift J
Draw a polyline (in Create polylines mode)   Click at each point of the polyline
Curve drawn polyline (in Create polylines mode)   Ctrl + Click at the end of the first segmentalt + Click at end of segment
Enter segment dimensions with the keyboard (in Create polylines mode)  Enter
End drawing a polyline (in Create polylines mode)  Esc / Double Enter in keyboard modeDouble-click at the last point
Display the modification pane of the selected polylinesPlan > Modify polylines…Ctrl Alt Shift Ecmd alt shift EDouble-click on a polyline
DIMENSION
Switch to the Create dimensions modePlan > Create dimensionsCtrl Shift Lcmd shift L
Draw a dimension (in Create dimensions mode)   Click at each end, move mouse to resize extension lines and click
Draw a dimension along a piece of furniture, a wall or a room side (in Create dimensions mode)   Move mouse on piece, wall or room side, double-click,  resize extension lines and click
Enter dimensions with the keyboard (in Create dimensions mode)  Enter
TEXT
Switch to the Add texts modePlan > Add textsCtrl Shift Tcmd shift T
Enter a new text   Click at text location and enter text
Display the modification pane of the selected textsPlan > Modify text Double-click on a text
Increase the text size of the selected items (texts, rooms, dimensions)Plan > Modify text style > Increase sizeCtrl Alt KCtrl Alt +cmd ctrl +
Decrease the text size of the selected items (texts, rooms, dimensions)Plan > Modify text style > Decrease sizeCtrl Alt Shift KCtrl Alt –cmd ctrl –
Toggle bold text style of the selected items (texts, rooms, dimensions)Plan > Modify text style > BoldCtrl Bcmd B
Toggle italic text style of the selected items (texts, rooms, dimensions)Plan > Modify text style > ItalicCtrl Icmd I
LEVEL
Add a levelPlan > Add levelCtrl Alt Ncmd alt N
Add a level at the same elevation as the selected onePlan > Add level at same elevationCtrl Shift Ncmd shift N
Select a level in plan  Arrows ← → with the focus on tabsClick on level tab
Display the modification pane of the selected levelPlan > Modify level…Ctrl Alt Bcmd alt BDouble-click on level tab
Make the selected level unviewable in the plan and 3D viewPlan > Make level unviewableCtrl Shift Hcmd shift H
Make the selected level viewable (when the level is unviewable)Plan > Make level viewableCtrl Shift Hcmd shift H
3D VIEW
Switch to Aerial view mode3D view > Aerial viewCtrl Dcmd D
Switch to Virtual visit mode3D view > Virtual visitCtrl Shift Dcmd shift D
Turn point of view around scene center in Aerial viewmode, or turn visitor head left, right, up and down in Virtual visitor mode  A D or Arrows ← → ⇞ ⇟Move mouse with left button pressed
Turn point of view or visitor head 5 times faster  Shift A D or Shift Arrows ← → ⇞ ⇟Shift + Move mouse with button pressed
Move forward/backward in Aerial view or Virtual visitormodes  W S or Arrows ↑ ↓Roll mouse wheelSwipe trackpad
or Alt + Vertical moves with button pressed
Move forward/backward 5 times faster  Shift W S or Shift Arrows ↑ ↓Shift + Roll mouse wheelShift + Swipe
or Shift + Alt + Vertical mouse moves with button pressed
Move visitor up and down in Virtual visitor mode  Home / End
Move visitor up and down 5 times faster  Shift Home / End
Move visitor sideways in Virtual visitor mode  Alt Arrows ← →
Move visitor sideways 5 times faster  Shift Alt Arrows ← →
Display the modification pane of the virtual visitor (in Virtual visitor mode)3D view > Modify virtual visitor…Ctrl Alt Mcmd alt M
Store the current point of view3D view > Store point of view…Ctrl Alt Rcmd alt R
Display the 3D view in a separate window3D view > Display in separate windowCtrl Alt Ycmd alt Y
3D view > Display in main window3D view > Display in main windowCtrl Alt Ycmd alt Y
Make all levels viewable in the 3D view3D view > Display all levelsCtrl Alt Acmd alt A
Make only the selected level and below viewable in the 3D view3D view > Display selected levelCtrl Shift Acmd shift A
Display the modification pane of the 3D view3D view > Modify 3D view…Ctrl Shift Mcmd shift M
HELP
Display Sweet Home 3D help windowHelp > Sweet Home 3D helpF1cmd ?
Notes:
  • Some icons cited in Icon column are not displayed in the toolbar
  • Home ⤒, End ⤓, Page up ⇞, Page down ⇟ keys can be accessed with fn + arrow keys on some laptop keyboards
  • Typing the + sign might require to also press the Shift key according to the layout of your keyboard
  • Under Mac OS X, a right click can also be achieved thanks to a click with ctrl key pressed
Thanks to OKH for his great help to build this list.
