e.g.
Code: Select all
+------------------+Code: Select all
+------------------+Well, in 2D view its the same when using the scroll-bars, right? But the trick using the space bar is useful, thanks!In the plan, the pan tool can be activated with the Plan > Pan menu item or temporarily with the space bar.
Well, this is, more or less, already the case when moving the figurine.In the 3D view, you will be able to move sideways in the coming version 4.4 when you're in Virtual visit mode.
