Re: Sweet Home 3D 3.0
An additional note about compatibility with SH3D files created with previous versions: - The compass rose isn't shown. Make it visible with Plan > Modify compass… menu item. - The values set for lens, date, time, time zone, North direction, latitude, longitude and ceiling lights in the Advanced rendering plug-in aren't used in version 3.0 and you'll have to copy them back if needed. By default, date/time is set to midday today, latitude/longitude are set from your time zone and ceiling lights are turned on. - All existing lights are turned off and the angle set on light sources isn't used for its power level. Adjust the power of each light with the new Light power spinner available in Furniture modification dialog. You can edit the power of more than one light at a time by selecting them and choosing Furniture > Modify... menu item.
I hope these changes won't bother you too much.
Emmanuel:
Thank you for the first beta of SH3D v3.
The compass shows when starting a new design, then disappears when loading a model made with a previous version. Unfortunately your solution doesn't work (under Ubuntu 10.04), because nothing happens: no pop-up window or anything.
On the side: would it be an idea to move these settings to the Preferences menu? The Plan menu is very long already, even when not counting the additions from the Edit plug-in.
Hans, the visibility of the rose may vary from a home file to the other. Use Plan > Modify compass… to make it visible or not. Note that it's drawn first in the plan, so it may be hidden by furniture.
I won't put compass settings in preferences because a user may want to display the compass at a different location in each home, and the geographic location of a home will generally vary too.
I just released the version 3.0 Beta 2 with two bug fixes: - 3D models that use fully opaque PNG textures aren't transparent internally anymore. This should fix a few cases like this one when some transparent objects are in front of each other. - SunFlow now supports transparent textures as the following image shows.
(the Eiffel Tower Collada file comes from Google Warehouse)
The new version does pan in the 3d view much more smooth than 2.6, and I do like the visible compass. Great improvements!
But I noticed there are some light issues that I'm not sure are just coming from me being new to the different settings, or if something could be tweaked in the renderers settings... Any of the lighting I made previously, or that I am experimenting with now, seems not to make nice complex shadow and light patterns. The colors of the lights also wash out, or become faded, especially if there is a window in the room. Not being able to turn off the sunlight affects the shadowing to a great degree. Even if I put a night time of day, the darkness doesn't look correct, and there is still a strong shadow.
I made these two renders with the same lights and furniture, and same view settings. The first is from the old Advanced renderer in 2.6. You can see how the colors show on the wall, and the lights themselves looked dim...
This is from 3.0 and the colors are much harder to see. I also had to remove the windows (I removed the windows from both version to make a fair comparison) I had in the room, or the light coming from the windows overpowered the small lights.
I know there isn't much of a difference between the two, but the color reflecting from the wall is what I was going to use in a couple of scenes I was working on. So I was just wondering if there are some settings that I could change myself?
Thanks for all your work to make this software!
And transparent textures are going to be a fun addition!
[Edit 1 times,
last edit by whippetsleek at Sep 28, 2010, 7:14:36 PM]
The lights in the second image look brighter. Did you try to reduce their power? I forgot to mention an other change that may change the rendering: the size of the light has an effect only on the new Light source added to the catalog. I will have to create a new SH3F lights file to make this feature available in the other lights too (at this moment, they will always have a 6.5 cm diameter).
I don't understand the problem you have with light coming through windows at night time. Do you use a bright texture in the sky? Do you still experience some problems if you use a color for the sky?
Thank you for your feedback.
As far as the Advanced Photo plugin, it tells me, "The current version of the plugin can't work in java web start. Please use this SweetHome 3D version available at..." (and it gives the download page address). So, I couldn't use it to test it. :(
Other than that, the new SH3D seems to work a little sluggishly but ok (My system is using the iced tea version of java by default). The compass rose is so huge when SH3D starts though. I have to keep modifying it to 24 inches to make it smaller.
I found where the sun java webstart executable is located so I tried it again using that version but I got the same results with the Advanced Photo plugin but the compass rose looked a lot better.
I opened a SH3D file that was created in 2.6 and then I made a couple of screenshots of an attempt to create a photo using the Create Photo tool, one with the default camera and the other was done using the depth of field option:
I hope you can see this but, there's a weird color to them (blue and green). The lights I had used were the normal yellow color.
[Edit 2 times,
last edit by pencilart at Sep 28, 2010, 8:53:54 PM]
I have changed some settings and this is what I have now...
The lights are still very bright, but the light from the window is lessened. But there still is a strong shadow outside the window. And I get more black spots with the window added for some reason? I have a dark grey texture added to the sky.
Pencilart, I also can not get the advanced renderer to work in the new 3.0, ( I get the same message) I am working with the built in renderer.
[Edit 1 times,
last edit by whippetsleek at Sep 28, 2010, 8:32:05 PM]
The Advanced Photo plugin could never run with Java Web Start. That's partly why it's time to integrate its features to Sweet Home 3D itself...
How is that possible??? Isn't it 3 feet / 1 meter wide? Does anybody else experience this problem?
It is set to 39.37 inches (3' 3 3/8"). In the Iced Tea version of Java it has an ugly looking thick ring around it that goes away when i resize it. Like I said, with the Sun javaws, it looks fine.
P.S. in the Sun javaws, SH3D is much more responsive than with the Iced Tea version. Hopefully, my browser will now use the Sun version all the time.
[Edit 1 times,
last edit by pencilart at Sep 28, 2010, 9:01:29 PM]
Emmanuel,
When I start SH3D v3.b2 I see the compass at top-left, sized 1x1 mtr. Using the handles, I can resize and rotate the compass, or drag it to a different location. But, as I reported before, when I open a model made with (e.g.) v2.6, I don't see the compass. I even can't see it when I move the model to the side. (See image)
Equally, as reported before, Plan --> Modify compass doesn't open a window to change the compass settings.
Maybe it's a Ubuntu-only problem?
(In Windows Vista, a v2.6 file doesn't show the compass either, but when I do Plan --> Modify compass a window opens and I can use the check-box to make the compass visible.)
On the side, maybe you can give the compass rose an elevation (or put it on a different layer), so that it always opens on top of the design? That way it would always be visible on startup.
Rendering seems to work OK, although (for the moment) I prefer the v1.6.1 version, and I didn't test it thoroughly yet.
