I have the 1.4 version but i cannot get the program to save anything. When i click on "save" or "save as" it will highlight and then nothing happens. over an over again. When i close the program, it will ask me to save and with i click the save button, again nothing happens.
someone help!
thanks everyone.
Will not save...
This topic has been viewed 3999 times and has 1 replies
Re: Will not save...
What Java version do you use (see in About dialog) ?
I think it's a problem in Java. If you installed Sweet Home 3D with Java Web Start try to update the Java version installed on your system. If you installed Sweet Home 3D with the installer, try to update the Java version installed on your system and then use the Java Web Start version of Sweet Home 3D available at http://sweethome3d.sourceforge.net/download.html
See also: https://sourceforge.net/tracker/index.php?func=detail&aid=1860446&group_id=152568&atid=784665
