How to generate a .h file with javah?
This topic has been viewed 10212 times and has 2 replies
enkonyito
Post by enkonyito »
In the [font=courier new]YafarayRenderer.java[/font] file of the new plugin , there is the procedure to generate the [font=courier new]YafarayRenderer.h[/font] file.
By replacing the initial packages with that of the PhotoVideoRendering plugin, I get this error message:
Error: Could not find class file for 'betaTest_plugin.YafarayRenderer'.
Enko
EnkoNyito
Re: How to generate a .h file with javah?
To generate a .h file, you have to compile first the class which contains [font=courier new]native[/font] methods, and add the path of the compiled class to the classpath used by javah.
Have a look to the comment of [font=courier new]loadDLLs[/font] method in [font=courier new]YafarayRenderer[/font] class to get more ideas.
enkonyito
Post by enkonyito »
Thank you Emmanuel!
Based also on this documentation, I was able to generate the [font=courier new]YafarayRenderer.h[/font] file in the plugin package.
/* DO NOT EDIT THIS FILE - it is machine generated */
#include <jni.h>
/* Header for class betaTestPlugin_YafarayRenderer */
#ifndef _Included_betaTestPlugin_YafarayRenderer
#define _Included_betaTestPlugin_YafarayRenderer
#ifdef __cplusplus
extern "C" {
#endif
 * Class:     betaTestPlugin_YafarayRenderer
 * Method:    createEnvironment
 * Signature: (Ljava/lang/String;Ljava/lang/String;)J
JNIEXPORT jlong JNICALL Java_betaTestPlugin_YafarayRenderer_createEnvironment
  (JNIEnv *, jobject, jstring, jstring);
Since I don't know JNI, generating DLLs is less obvious and I get an error in Eclipse when rendering.
It's easier with the modified YafaRay rendering plugin because I kept your packages and added the necessary files and folders.
EnkoNyito
