Blueprint edit
This topic has been viewed 5410 times and has 0 replies
coldcomfort
- Member
Blueprint edit
Would be quite useful if we could manipulate a blueprint like any object, resize or move it around and rotate it around the central axis or change its transparency level. Directly on the floorplan, not beforehand in blind. For example playing around with a historical building with patchy blueprints for different levels and from different sources. The blueprint edit function doesn't allow for much when adding a second level blueprint with a different orientation.
