I have a suggestion that might make the levels menu a bit easier to read.
Using words like hide and show instead of make, and also grouping it, the menu could look something like this:
Add level
Add level at same elevation
Hide selected level
Show only selected level
Show all levels
Modify selected level
Delete selected level
Could this be an idea?
What do you think?
About the levels menu
This topic has been viewed 6431 times and has 3 replies
Re: About the levels menu
I used Make viewable / unviewable rather than Hide / Display / Show to avoid confusion with the Display menu items in the 3D view menu. So a level can be viewable but hidden in the 3D view.
I see the problem.
Show and Hide are common terms, but they might, as you point out, create confusion.
Another thing:
Would it be possible that the modify level window could pop up automatically when adding a new level? That would be great for naming and for setting height and especially floor thickness, something I have noticed that I tend to forget.
Another thing:
- Ceciliabr
- Country: Copenhagen, Denmark
- Contact:
@Xiste:
I absolutely agree with you!
To make something un-viewable is just a complicated way of saying hide.
Hide and show are much better terms, as they are precisely to the point and immediately leads you in the right direction.
I really don't see Puybaret's point here, and how this can create any confusion. We're dealing with the visibility of levels. What can that possibly be confused with?
That said, I think custom shortcuts would be a great idea as the program continues to expand and get more and more options.
Photoshop has several hundreds commands we can define our own personal shortcuts for.
The automatic pop-up is also a great idea!
