Hi Puybaret,
I‘m loving your program and we are using it to plan your new home.
From the current project I have two feature request.
1. Make it possible to have labels and polylines not only in the base plan.
I’m using text and polyline to comment furniture. To avoid to accidentally move walls and rooms I locked the base plan. But then I cannot move the polylines and labels.
2. Make it possible to lock all objects that are not part of a level. I’m using different levels at the same height. E.g. Level 1: walls, rooms; Level 2: furniture; Level 3: 2D symbols for electricity planing, etc. When I’m moving the 2D symbols I don’t want to accidentally move furniture (which are at a different level).
I’m a software developer so I can try to implement these features myself (I already complied Sweet Home 3D).
Puybaret what do you think how complicated it is to implement 1. or 2.?
Best regards,
Albrecht
Labels and polylines not in base plan and lock all objects that are not part of a level
This topic has been viewed 9658 times and has 3 replies
Re: Labels and polylines not in base plan and lock all objects that are not part of a level
For 1 I did a quick patch which works for me.
See here: https://github.com/AlbrechtL/SweetHome3 ... 98158f770d
I think the best would be to add a "part of base plan" check box to the label and polyline dialogs (like it inside the furniture dialog).
I also solved point 2 by adding a check box to the level dialog. Now every level can be lock separately.
Code changes: https://github.com/AlbrechtL/SweetHome3 ... 4ab2fec0b9
For everyone who want to try it. You can find a JAR file here: https://github.com/AlbrechtL/SweetHome3D/releases
