Additional Sunflow options (tests)
This topic has been viewed 19914 times and has 13 replies
enkonyito
Post by enkonyito »
Sunflow has command line options to control the rendering result without the GUI.
The goal here is to test their actions in Sweet Home 3D.
* Option:
-threads X
Allows you to force the number of threads used for rendering (BucketRenderer, MultipassRenderer).
Default value: number of available processors.
SH3D implementation:
[font=courier new]int threads = X;
this.sunflow.parameter("threads", threads);
this.sunflow.options(SunflowAPI.DEFAULT_OPTIONS);[/font]
Image Image Image
No major differences in rendering time if the number of virtual threads is greater than the number of actual threads available.
Image Image
* Options:
-lopri
-hipri
Allows you to set the priority of the threads.
Default value: lowPriority = true.
[font=courier new]boolean lowPriority = true;
this.sunflow.parameter("threads.lowPriority", !lowPriority);
No major differences in rendering time.
EnkoNyito
enkonyito
Re: Additional Sunflow options (tests)
Post by enkonyito »
* Option:
-showaa
Display sampling levels per pixel for bucket renderer.
Default value: showAA = false.
[font=courier new]boolean showAA = false;
this.sunflow.parameter("aa.display", !showAA);
showAA = true
Image Image
Image Image Image
showAA = false
EnkoNyito
enkonyito
Post by enkonyito »
* Options:
-quick_uvs : Renders the UVs of objects.
-quick_normals : Renders the normals of objects.
-quick_id : Renders using a unique color for each instance.
-quick_prims : Renders using a unique color for each primitive.
-quick_gray : Renders all the objects in the scene gray diffuse, overriding all shaders.
-quick_wire : Renders objects as wireframe.
-quick_ambocc X : Renders a scene in ambient occlusion mode with a certain distance (X).
Only one override shader at a time can be used.
[font=courier new]String shaderOverride = null; // "show_uvs","show_normals","show_instance_id","show_primitive_id","quick_gray","wireframe","ambient_occlusion"
if (shaderOverride.equals("ambient_occlusion")) {
float maxDist = 200f;
this.sunflow.parameter("maxdist", maxDist);
this.sunflow.shader("cmdline_override", shaderOverride);
this.sunflow.parameter("override.shader", "cmdline_override");
shaderOverride != null
Image Image Image
Image Image Image
EnkoNyito
Post by VeroniQ »
Nice renderings!
enkonyito
Post by enkonyito »
Nice renderings!
Thank you VeroniQ!
I take the opportunity to propose a small survey.
Among the new rendering options, which ones do you find most interesting?
A: show_uvs
B: show_normals
C: show_instance_id
D: show_primitive_id
E: quick_gray
F: wireframe
G: ambient_occlusion (X)
EnkoNyito
Post by VeroniQ »
I like E: Quick Grey but the colored ones (especially C and D) are fun!
ndorigatti
Country: Italia
Post by ndorigatti »
quick gray, wireframe and ambient occlusion (E F G)
enkonyito
Post by enkonyito »
The additional Sunflow options plug-in will be available with the new version of the photo-video plug-in.
Enko
EnkoNyito
williamcm
Country: Cameroun
Post by williamcm »
Hello hello community
how to install SunFlow
I would like to improve my rendering and how to use it? i have already downloaded but there is no executable file
Thank you william from Cameroon
Hello bonjour la communaute
comment installer SunFlow
je voudrais ameliore mes rendue et comment l utiliser? j ai telecharger deja mais il ya pas de fichier executable
Merci william depuis le cameroun
enkonyito
Post by enkonyito »
Hi William!
You can download the precompiled version Sunflow-v0.07.2 and run the sunflow.jar file directly or sunflow.bat after editing.
You can also download the latest version Sunflow-v0.07.3 and follow the build instructions of the README file.
Enko Nyito
EnkoNyito
