"schräge" Box zeichnen?
This topic has been viewed 3795 times and has 5 replies
Luzi3D
Post by Luzi3D »
Hallo,
gibt es die Möglichkeit, eine Kist so zu editieren, dass sie nicht rechtwinklig ist, sondern in der Draufsicht schräge Kanten hat? Ich hoffe, man versteht, was ich meine ;)
Danke und LG
Luzi
Country: UK
Re: "schräge" Box zeichnen?
Post by Mike53 »
I am not sure if you can edit a box, but you can certainly make the shape you describe with the shape generator tool, you will find it tools>generate 3d shape
Luzi3D
Post by Luzi3D »
where do I find "tools"?
Thanks!!
Country: UK
Post by Mike53 »
drop down box top left of main screen file...edit...Furniture...etc
Luzi3D
Post by Luzi3D »
Ahh found it, it's a plug in :)Thank you!!
Country: UK
Post by Mike53 »
If the shape you require has more points than the generator allows then an option would be to draw the profile of your shape with the "create room tool, this will need to be done on an elevated level, not 0 elevation, then export it, 3D view>export to obj format, then import it, furniture> import furniture, during the import process you can re-orientate the object.
