I have been working very hard on a design recently.
Today I decided to take time out, use Enko's fantastic advanced photo video editing plugin and make my own Grand Designs flyby video.
Regular watchers of the show which originates in the UK but has spawned versions in Australia and New Zealand will know the anticipated sequence near the start of the show where a 3d model of the proposed build self assembles whilst a familiar sound track plays out. Its all achieved using expensive software, a team of pros and I would also guess a render farm.
Here is my attempt....(please watch in HD if possible) - the original video on my machine is pin sharp and judder free.
https://youtu.be/W4IcChikcDc
I was wise enough to show mine before the pro version, a small band might open for the main act but the reverse is just setting yourself up !!
And here is the pro version
https://youtu.be/cXmv0psT5GU?t=11
It was a lot of fun doing that - needed a break [B-)]
Attempt At A GrandDesigns video flyby
This topic has been viewed 8072 times and has 8 replies
Re: Attempt At A GrandDesigns video flyby
The Youtube video I posted missed the roof replacement, here is the intended version
https://youtu.be/wiidLNcVtWc
If I can I will delete the whole post and start again.
[Note from moderator: fixed URL]
"If I can I will delete the whole post and start again."
No ! I get the error message "Cant delete a thread that has a reply"
Glorious irony [:))] Give up !
Have to say that is not only a beautiful design but an excellent flyby too, the hrs you have put in are well worth it, if this is going to be built, i really look forward to seeing build images and comparisons.
You and your better half both deserve congratulating.
Link to modified flyby not working.
You could ask Puybaret if he would kindly edit it for you with the correct link
Thanks Mike - yes you know how it is, you make one mistake and then try to rectify and make another and then before you know where you are you are sitting in a pile of rubble wondering if some kind soul will take pity on you and mix you a nice ice cold "G & T" - everything aspect of life needs an "edit" option
Right no links in this post maybe I am safe to press "Reply".
Right one last time before I go for the ice.
If I can't get this right then I should definitely not be allowed on a building site never mind doing a self build. [:-/]
Very nice video [:)]
I fixed the URL in your second post.
Thanks Emmanuel - appreciated !
