Desktop shortcut?
This topic has been viewed 4812 times and has 7 replies
pencilart
Desktop shortcut?
Post by pencilart »
Can I make a desktop shortcut so I won't be having to open the terminal every time I want to run SweetHome3D?
Re: Desktop shortcut?
You can view SweetHome3D file content : it is just a command that should be run inside SweetHome3D-1.1 directory.
Maybe, renaming it as SweetHome3D.sh should make it double-clickable.
Which system are you using ?
pencilart
Post by pencilart »
I'm using SuSE 10.0 and KDE for my desktop environment.
pencilart
Post by pencilart »
P.S. I renamed SweetHome3D like you said but that did not work.
In Konqueror, try Create New File->Link To Application...
See http://docs.kde.org/stable/en/kdebase/konqueror/making.html
pencilart
Post by pencilart »
ok, I finally got that to work. I had forgotten about the ' that should surround the path.
I also had to put the path in the work path area.
Thanks!!
jw_e_dan
Post by jw_e_dan »
Why plenty of "Help" messages from sweet home 3D users appeared on my mailbox?!
I'm not the person who created this software!
So HELP! my mailbox is full of messages I'm not concerned with!
You probably subscribed to this forum.
In the messages you received, there should be a link to unsubscribe to Help forum. Simply, click on it ! ;-)
