Several problems.
Running Windows 10 Pro 64bit. Updated to latest version as of 25/03/2019
I can't run the editor just by double clicking it.
I have to use the command line, and it runs fine.
Re-installed java and still have the same problem. I have checked the java config file and Java is enabled. associated .jar files to run with the java.exe .
Second problem
Where are the textures located. It seems windows has a messy way of storing files, found some textures here AppData\Roaming\eTeks\Sweet Home 3D\textures but these are zip files. Also I was unable to locate this directory path using the editor first try. Opened file explorer and navigated to the textures path , then tried again in the editor and it worked.
Third problem
I have accidentally imported the same texture twice and want to delete one of them.
Program idea.
It would be nice to be able to display all available textures in a way similar to the objects in Sweethome 3d and be able to modify them within the program
Many thanks and look forward to your replies.
Texture Library Editor
This topic has been viewed 8691 times and has 7 replies
techdoctor
- Country: Spain
- Contact:
techdoctor
- Country: Spain
- Contact:
Re: Texture Library Editor
So no takers on helping me with the problems then.
On your 3rd issue.. if you select an item, any will do, >modify>texture, all imported textured names are in italics, when you select them the delete option becomes active, this is not the case for stored textures.
Never used the editor so i cannot help with other issues.
techdoctor
- Country: Spain
- Contact:
Thanks Mike, can't believe I missed that.
I can't be the only one who can't get .jar files working by double clicking them.
I did a google and followed the advice there but still no joy.
I never could get it to open with double click rither, windows 7,it may have an association issue, java i believe, but not sure on that, then when i did open it i had no idea what to do with it [:D] as usual, so i got rid.
techdoctor
- Country: Spain
- Contact:
Just created a bat file using note pad. in notepad write this
java -jar FurnitureLibraryEditor-1.24.jar
Now save it as a .bat file. Furniture editor and texture editor now work.
How I hate Windows
How I hate Windows
I am sure people, not me personally, will find this helpful, 2 questions though, what would the string for the texture editor be and i assume you created the .bat file while it was on your desktop, is it still there or did you have to place it elsewhere?
techdoctor
- Country: Spain
- Contact:
The Bat file is in the same folder as the Texture Library Editor.
Open notepad and write this
java -jar TextureLibraryEditor-1.6.jar
and save it as a .bat file
