Can you release version without JRE bundled also?
Release w/o JRE
This topic has been viewed 6548 times and has 4 replies
Re: Release w/o JRE
Did you see that Sweet Home 3D is also available as a Java Web Start application at http://sweethome3d.sourceforge.net/download.html ?
I could build a Jar file without a bundled JRE, but felt that Java Web Start solution was enough and better at this time (a Jar file may be run with a double click, but you don't get file extension associations and program icon).
Why would you need such a Jar file ?
Randal_Lovelace
Re: Release w/o JRE
Part of the installation problem seems to be the whole .jar thing... Most 'users' aren't 'that computer savvy, so why make it complex.
You've made a nice .exe for WINDOWS USERS... why not make a .rpm for Linux?
Re: Release w/o JRE
> Why not make a .rpm for Linux?
There's no special reason. It's just I thought the .tgz file is easy to unzip *and* to uninstall (in case of
Before changing, I would like to be sure that Linux people are more used to install .rpm files...
BTW, would you have a link to a nice and short .rpm builder tutorial ?
Re: Release w/o JRE
I found this in LinuxQuestions.org:
http://www.linuxquestions.org/questions/susenovell-60/how-to-build-rpm-in-10.3-594066/?highlight=build+rpm
I know this is for SuSE but there should be a buildrpm package for your system. Anyway, it refers to this tutorial from Novell: http://en.opensuse.org/SUSE_Build_Tutorial
