Can't run application
This topic has been viewed 6033 times and has 1 replies
Jason_Mazzotta
Post by Jason_Mazzotta »
I'm trying to run Sweet Home 3D on windows. I'm using NetBeans to build and run the application. I was able to compile the application. However, when I try to run it, I get:
java.lang.NoClassDefFoundError: and
Exception in thread "main"
Can anyone tell me how I can trace the source of this error?
Thanks,
Jason Mazzotta
Re: Can't run application
The easiest way to run Sweet Home 3D is with its online JNLP file available at http://sweethome3d.sourceforge.net/SweetHome3D.jnlp .
If you want to run it from NetBeans you should run the class com.eteks.sweethome3d.SweetHome3D with the system property java.library.path equal to the lib/windows Sweet Home 3D sub directory (thanks to the Java option -Djava.library.path=path/to/lib/windows).
