Levels questions
This topic has been viewed 5559 times and has 4 replies
tarpon
Country: Canada
Levels questions
Post by tarpon »
I have 2 questions about using multiple levels.
I have created a base level (main floor) and 3 other levels FrontPorch, Furniture1 and Furniture2 all at the same elevation. When I click on the levels above the main window the base level is visible and I can add items in the other levels.
But when I create a Level4 ( a second floor) all my other levels disappear and I can not use the base level as a guide.
What am I doing wrong?
Also, is it possible to merge levels?
Thanks very much,
Tarpon
Country: UK
Re: Levels questions
Post by Mike53 »
Hi tarpon
1. Try going to the drop down window "3d view" and select "display all levels".
2 by merge i am going to assume you mean to show all furniture (objects) on 1 level instead of 2 or 3, if that is the case, select 2 or 3 items on the level to move, then right click >select all, you can then either cut and paste to the required level or copy/paste whichever you are comfortable with.
tarpon
Country: Canada
Post by tarpon »
Hi Mike.
1. I can see that I didn't explain the situation well enough. All levels appear in the 3D window, my Level 4 "Second floor" sits, at what appears to be about 18", above the first floor levels. In the design window I can not see the first floor levels at all when I have Level 4 active and have only been able to position the "2nd floor" by using the positional measurements from the lower levels. "3d view" and select "display all levels".... didn't change the situation :-(
2. By merge I mean to condense multiple levels in to one single level... can that be done?
Any other thoughts? Is the program limited in number of levels per file?
Thanks again for the help,
Tarpon
UbuntuBirdy
Country: Switzerland
Post by UbuntuBirdy »
Lower your "Second floor" until you can see the walls/furniture from the "main floor". Then Position your "Second floor" as you need it. And if all is as it should be, rise your "Second floor" to your desired height.
Pascal
tarpon
Country: Canada
Post by tarpon »
UbuntyBirdy,
That solved the problem. Thanks very much.
Tarpon
