Split walls aaarrrghhhh.
This topic has been viewed 2457 times and has 3 replies
Country: UK
Post by Mike53 »
Hi.
Having spent several hours moving a wall texture (tiles) on both x and y axis with several split sections , i was very pleased with the addition to allow this and the result, however, when i found it necessary to split the wall for the adjoining room i noticed that my tiling was ruined. Would it be possible in future to designate which side of the wall to split, or should i use 2 parallel walls.
Country: UK
Re: Split walls aaarrrghhhh.
Post by Mike53 »
I apologise for posting this here, it should probably have gone into "developers".
Did you try to adjust the X offset of the texture on the side of the wall you didn't want to change?
Country: UK
Post by Mike53 »
Sorry Emmanuel, missed your reply. I did try but it got too frustrating changing each side to find a match, instead i used twin (cavity) walls, this brought action brought its own issues, windows, doors etc, they seemed easier to work with.
Thanks
