Combining the linked pool and the double garage......
This topic has been viewed 21548 times and has 27 replies
Country: UK
Post by Mike53 »
Coming up with a property that would have the pool and garage that i shared here always meant that the design would be kinda grand/ish.
So here are a few images of the project so far.
Front
Rear
Several of the entrance
The Pool showers, wall and doors removed for the render.
And the kitchen....so far
And a Link to view it.
Looking forward to any comments.
nemetonia
Re: Combining the linked pool and the double garage......
Post by nemetonia »
I love the stairs ! [:x]
Nice day.
Country: UK
Post by Mike53 »
Thank you nemetonia, the hand rails are cylinders and spheres, the treads are currently box's, I may change them to rooms to give a glass appearance ànd the riser/stringer's are rooms. Took a while to make them but I am pleased with the result..
Country: UK
Post by Mike53 »
Quick update on the outside of the project.
Window color/texture has been changed, fascia's and soffits positioned, gutters and drain pipes included. Changed the outdoor pool slightly edging and water, and a few plants added
Front
and rear
Country: UK
Post by Mike53 »
Updated views of the kitchen and the breakfast area.
Country: UK
Post by Mike53 »
A few more images and the projects layout :-
The Games room first.
I couldn't find a reasonable baize for the pool table so i ended up trying grass, reduced to 5% of its original size, seems ok to me. A roof by Kerwin and 1 of Enkonyito's lamps are used over the pool table. A dozen walls, 3 rooms and 4 cylinders were used to make the enclosure for the dart board. The lamp illuminating the dart board is from the library, exported turned and imported, with a second original lamp, (body invisible) positioned to supply the light.
Lounge /Diner
I am posted these images whilst i have already decided to change the wall texture (yuk)
And replace the dining table and chairs (poor mapping).
The projects has basically 3 floor plus a sunken kitchen floor, but i have used 7 levels in total to create them.
From the bottom up :-
Games room, cinema and Gym are all below ground and therefore windowless, the floor of the indoor pool is also visible.
The turntables in the garage.
The 2 pools.
The kitchen and the as yet unseen new indoor water feature.
Ground floor has a breakfast area, a powder room and WC, Lounge/ diner, Utility room, main entrance and outside seating.
Ist Floor comprises 5 bedrooms all with ensuite, most with walk in closets, 2 linen closets and a large balcony.
Which just leaves the roofs. On this project i used all walls the create both roofs and ceilings.
Image.
Hope you like them.
Country: UK
Post by Mike53 »
Here is another image of the entrance but with the addition of the new indoor water feature.
Country: Copenhagen, Denmark
Post by Ceciliabr »
Nice work, Mike!
Lots of cool features and details.
Merry Christmas
Cecilia
Country: UK
Post by Mike53 »
Thank you Cec and have a good one yourself [:)]
Lounge after tweaks.
Country: UK
Post by Mike53 »
Managed to get started on the 1st floor today. So here is an image of the 1st bathroom (wall removed for view).
Image.
