I would like to design a kitchen. I have found a set of kitchen cabinets which I would like to import into SH3D. I have downloaded it as an Collada File. I have imported the object as a single furnature. When I drag it onto my drawing, its a single object with all the caibinets. How can I import it and use al its cabinets/object seperately?
The 3d set: https://3dwarehouse.sketchup.com/model/ ... abinet-Set
Thank you in advance, regards,
Bas
Import set of objects
This topic has been viewed 3753 times and has 4 replies
Re: Import set of objects
1 - install SketchUp
2 - open your kitchen file
3 - delete all models except one
4 - export your model
5 - use Undo to restore all models
6 - repeat steps 3 to 5 until all models are exported
Good luck!!
Good luck!!
As I’m not sure that the free version of SketchUp will allow you to export a file at Collada format, I would import it in Blender which will let you export to OBJ or Collada formats only the selected object.
Install SketchUp 2015, last free version with export.
Got it working with SketchUp 2015, thanks !
