sad High priority how should i fix this?
This topic has been viewed 5615 times and has 5 replies
farasat
Country: KORDESTAN
Post by farasat »
hi every one
i have a problem using sweet home 3d
like what you can see in this image
when i click ok sweet home 3d closes
this problem is in 5.0 and newer versionsImage
thanks in advanced
Re: how should i fix this?
Under what system did you try?
farasat
Country: KORDESTAN
Post by farasat »
Run the installer again, and select the 32 bit option when the installer prompts you to choose the destination folder.
farasat
Country: KORDESTAN
Post by farasat »
i did it and the error has fixed
I really appreciate your help
Raevlav
Country: Rus
Post by Raevlav »
After upgrading to v.6 'Catalog icons' option of 'Furniture icons in plan' in 'Preferences' is not available. So all the models at plan now are shown as top view icons.
Also two lowest (fastest) qualities in 'Create photo' are not available too (the slider just cannot be moved to the corresponding positions).
i have fixed the issues by the same solution - reinstall SH from 64bit to 32bit ver.
