This has probably been asked before...how can I draw a small circle to use as a column?
Why isn't there a tool to draw circles and ellipses?
Many thanks.
Draw Round Column
This topic has been viewed 7655 times and has 6 replies
stef.salmon
- Country: UK
ndorigatti
- Member
- Country: Italia
Re: Draw Round Column
You can use cylinder object!
stef.salmon
- Country: UK
Cylinder object from where?
- bdfd
Hi,Hi,
It's a standard object made by Emmanuel ! [;)]
1 - draw two walls which start and end at the same coordinates.
2 - give one wall an arc of 180 degrees, the other of minus 180 degrees.
or look here
or look here
The cylinder object can be found in the Miscellaneous category.
stef.salmon
- Country: UK
Perfect...thank you all for your replies [:)]
