moving all parts at once (in z coordinate)
This topic has been viewed 3268 times and has 2 replies
hans_wurst
Post by hans_wurst »
I draw the hole top floor. But I did the mistake to think about the distance to the ground. Now, I would like to add the ground floor.
Is there any option to move all ready-made parts 2 meters upside? (so that I would have the place for the ground floor than) Or do I have to change the position individual for every single part now?
Thank you for answer.
Country: Copenhagen, Denmark
Re: moving all parts at once (in z coordinate)
Post by Ceciliabr »
Add a new level at the same elevation. Modify your original level by increasing the elevation to the desired height ( whereas all your furniture, objects, walls and rooms will be elevated simultaneously ), and construct your ground floor on the new level.
hans_wurst
Sorry for the late response. Now everything is fine. Thank you.
