Misc typo fix patch
This topic has been viewed 4914 times and has 0 replies
Kunda
Misc typo fix patch
Post by Kunda »
Patch cleans up some typos in the code.
Can be applied with:
patch -p0 < sweethome3d-typos.patch
diff --git trunk/SweetHome3D/build.xml trunk/SweetHome3D/build.xml
index ea94089a4..87103f936 100644
--- trunk/SweetHome3D/build.xml
+++ trunk/SweetHome3D/build.xml
@@ -27,7 +27,7 @@
      - sourceArchive          : Builds SweetHome3D-version-src.zip file in install directory
      - javadoc                : Builds SweetHome3D-version-javadoc.zip file install directory
-     - jdepend : Launchs a JDepend graphical UI to help update dependencies in PackageDependenciesTest
+     - jdepend : Launches a JDepend graphical UI to help update dependencies in PackageDependenciesTest
 <project basedir="." default="jarExecutable" name="SweetHome3D">
   <!-- The current version of Sweet Home 3D -->
@@ -1382,9 +1382,9 @@
     <echo message="install/SweetHome3D-${version}-javadoc.zip ready for ftp"/>
   </target>
-  <!-- Launchs a JDepend graphical UI to help update dependencies in PackageDependenciesTest test -->
+  <!-- Launches a JDepend graphical UI to help update dependencies in PackageDependenciesTest test -->
   <target name="jdepend" depends="build"
-          description="Launchs a JDepend graphical UI">
+          description="Launches a JDepend graphical UI">
     <!-- Create jdepend.properties file in build directory that specifies ignored Java packages -->
     <concat destfile="build/jdepend.properties">ignore.java=java.*</concat>
diff --git trunk/SweetHome3D/src/com/eteks/sweethome3d/applet/HomeAppletRecorder.java trunk/SweetHome3D/src/com/eteks/sweethome3d/applet/HomeAppletRecorder.java
index 69816c441..d649fb800 100644
--- trunk/SweetHome3D/src/com/eteks/sweethome3d/applet/HomeAppletRecorder.java
+++ trunk/SweetHome3D/src/com/eteks/sweethome3d/applet/HomeAppletRecorder.java
@@ -171,7 +171,7 @@ public class HomeAppletRecorder implements HomeRecorder {
     URLConnection connection = null;
     DefaultHomeInputStream in = null;
     try {
-      // Replace % sequence by %% except %s before formating readHomeURL with home name
+      // Replace % sequence by %% except %s before formatting readHomeURL with home name
       String readHomeURL = String.format(this.readHomeURL.replaceAll("(%[^s])", "%$1"),
           URLEncoder.encode(name, "UTF-8"));
       // Open a home input stream to server
@@ -278,7 +278,7 @@ public class HomeAppletRecorder implements HomeRecorder {
     HttpURLConnection connection = null;
     try {
       String deletedHomeURL = String.format(this.deleteHomeURL.replaceAll("(%[^s])", "%$1"),
       // Send request to server
diff --git trunk/SweetHome3D/src/com/eteks/sweethome3d/io/Base64.java trunk/SweetHome3D/src/com/eteks/sweethome3d/io/Base64.java
index 596cd74be..e7f8e3c97 100644
--- trunk/SweetHome3D/src/com/eteks/sweethome3d/io/Base64.java
+++ trunk/SweetHome3D/src/com/eteks/sweethome3d/io/Base64.java
@@ -453,7 +453,7 @@ public class Base64 {
    * anywhere along their length by specifying
    * <var>srcOffset</var> and <var>destOffset</var>.
    * This method does not check to make sure your arrays
-   * are large enough to accomodate <var>srcOffset</var> + 3 for
+   * are large enough to accommodate <var>srcOffset</var> + 3 for
    * the <var>source</var> array or <var>destOffset</var> + 4 for
    * the <var>destination</var> array.
    * The actual number of significant bytes in your array is
@@ -785,7 +785,7 @@ public class Base64 {
-     * are large enough to accomodate <var>srcOffset</var> + 4 for
+     * are large enough to accommodate <var>srcOffset</var> + 4 for
      * the <var>source</var> array or <var>destOffset</var> + 3 for
      * This method returns the actual number of bytes that
diff --git trunk/SweetHome3D/src/com/eteks/sweethome3d/model/Room.java trunk/SweetHome3D/src/com/eteks/sweethome3d/model/Room.java
index c9be41efb..ae0cc909c 100644
--- trunk/SweetHome3D/src/com/eteks/sweethome3d/model/Room.java
+++ trunk/SweetHome3D/src/com/eteks/sweethome3d/model/Room.java
@@ -80,7 +80,7 @@ public class Room extends HomeObject implements Selectable, Elevatable {
   public Room(float [][] points) {
     if (points.length <= 1) {
-      throw new IllegalStateException("Room points must containt at least two points");
+      throw new IllegalStateException("Room points must contain at least two points");
     this.points = deepCopy(points);
     this.areaVisible = true;
@@ -319,7 +319,7 @@ public class Room extends HomeObject implements Selectable, Elevatable {
     if (index < 0 || index >= this.points.length) {
       throw new IndexOutOfBoundsException("Invalid index " + index);
     } else if (this.points.length <= 1) {
-      throw new IllegalStateException("Room points must containt at least one point");
+      throw new IllegalStateException("Room points must contain at least one point");
     float [][] newPoints = new float [this.points.length - 1][];
