confused Light properties
This topic has been viewed 3455 times and has 9 replies
Light properties
Post by bdfd »
who knows the name of the property to fix the brightness of a light source in the properties file named 'pluginFurnitureCatalog.properties' ?
Re: Light properties
The property is [font=courier new]lightSourceColor#...[/font], fully black matching no light, and white #FFFFFF matching a white light at full power.
See DefaultFurnitureCatalog.properties for examples.
Post by bdfd »
Thank your for your return.
My ask has been not understand perhaps by using bad words, I wanted to say the power of lightsource (0 to 100%) and not the color. [:D]
I want to change the default value (50%) to 5% (for example).
but… I didn't see this in given file.
You can find all the properties in DefaultFurnitureCatalog.PropertyKey.html.
You will, as indicated by Puybaret, need to adjust RGB down in sync. The power is, however, saved in Home.xml, as that reflects the adjustment made by the user in the design.
Post by bdfd »
Great !
Do you know how to update this data in a sh3f file ?
[:D]
Use a zip utility to extract the [font=courier new]PluginFurnitureCatalog.properties[/font] file from a SH3F file and rezip it at the end, and a text editor to edit the [font=courier new]PluginFurnitureCatalog.properties[/font] file.
Sorry if I was unclear. There is no power setting in .sh3f/PluginFurnitureCatalog.properties (only in .sh3d/Home.xml). In .sh3f/PluginFurnitureCatalog.properties you can use the html (six digit hex) colour notation:
a very bright white light would be:
 lightSourceColor#xxx=#FFFFFF
a 'normal sh3d white' lightsource is (if I remember):
 lightSourceColor#xxx=#BBBBBB
a much less bright 'white' light would be:
 lightSourceColor#xxx=#222222
Post by bdfd »
TY okh.
Damned, a parameter only manually update. [:((]
Perhaps a adding to do in whislist section for next 5.8… [;)]
enkonyito
Post by enkonyito »
@bdfd
This is possible in a derived version of SH3D by modifying line 53 of the HomeLight.java file.
EnkoNyito
Post by bdfd »
@bdfd
TY enkonyito.
But I don't like this because it's "all or nothing"... [:D]
I explain : I want to update ONE object in a sh3f not all objects of same type in SH3D.
