Hi there,
Is it any possibility to set up a sunshine angle and direction through window into a building etc?
Cheers
How to set up sunshine thru window and shadow inside of a building?
This topic has been viewed 4289 times and has 1 replies
peterweaver
- Member
- Country: UK
Re: How to set up sunshine thru window and shadow inside of a building?
The rendering relies on the settings in the compass to provide correct sunlight direction. If you set orientation, lat/long and time/date you can get all possible sunlight angles. Look for enkonyito's and Ceciliabr's forum posts on Photo-video rendering if you need to adjust further light parameters. But yes, you can get pretty much any illumination you wish. okk..sunshine angle and direction through window into a building...
