By installing SH3D, the installation program ask for installing an old JAVA machine. Seems dangerous regarding security issues.
This problem will be solved asap ?
Thank you for your help
André
Installation on Mac El Capitan 10.11.6
This topic has been viewed 4509 times and has 3 replies
Re: Installation on Mac El Capitan 10.11.6
Certainly not ASAP because it’s not dangerous. If it was, do you really think that Apple would keep it available on its servers?
Anyway, if you don’t want to install Apple Java 6, you can install Oracle Java 8 and run Sweet Home 3D with Java Web Start.
And one more thing: the JNLP file doesn't work under the default settings for the most recent versions of macOS:
“SweetHome3D.jnlp” can’t be opened because it is from an unidentified developer. Your security preferences allow installation of only apps from the App Store and identified developers.
As explained in instructions about Java Web Start :
click on the SweetHome3D.jnlp downloaded file while maintaining the ctrl key pressed, and choose Open in the contextual menu that will appear.
