ver 5.7 on Linux "Can't create graphics environment"
This topic has been viewed 8352 times and has 5 replies
richardlyons
Post by richardlyons »
Installed 5.7 from the tgz 'SweetHome3D-5.7-linux-x64.tgz' and happily the program opens via 'SweetHome3D-Java3D-1_5_2', and runs 2D layout.
However there is no 3D rendering, and the following errors are logged on startup
$ /opt/SweetHome3D-5.7/SweetHome3D-Java3D-1_5_2
amdgpu_parse_asic_ids: Cannot parse ASIC IDs: Ressource temporairement non disponible
Exception in thread "AWT-EventQueue-0" javax.media.j3d.IllegalRenderingStateException: Can't create graphics environment for Canvas 3D
        at com.eteks.sweethome3d.j3d.Component3DManager.getCanvas3D(Unknown Source)
        at com.eteks.sweethome3d.j3d.Component3DManager.getOnscreenCanvas3D(Unknown Source)
        at com.eteks.sweethome3d.swing.HomeComponent3D.createComponent3D(Unknown Source)
        at com.eteks.sweethome3d.swing.HomeComponent3D.access$200(Unknown Source)
        at com.eteks.sweethome3d.swing.HomeComponent3D$1.ancestorAdded(Unknown Source)
        at javax.swing.AncestorNotifier.fireAncestorAdded(AncestorNotifier.java:86)
        at javax.swing.AncestorNotifier.componentShown(AncestorNotifier.java:193)
        at java.awt.AWTEventMulticaster.componentShown(AWTEventMulticaster.java:180)
        at java.awt.AWTEventMulticaster.componentShown(AWTEventMulticaster.java:179)
        at java.awt.Component.processComponentEvent(Component.java:6365)
        at java.awt.Component.processEvent(Component.java:6313)
        at java.awt.Container.processEvent(Container.java:2237)
        at java.awt.Window.processEvent(Window.java:2025)
        at java.awt.Component.dispatchEventImpl(Component.java:4889)
        at java.awt.Container.dispatchEventImpl(Container.java:2295)
        at java.awt.Window.dispatchEventImpl(Window.java:2746)
        at java.awt.Component.dispatchEvent(Component.java:4711)
        at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:760)
        at java.awt.EventQueue.access$500(EventQueue.java:97)
        at java.awt.EventQueue$3.run(EventQueue.java:709)
        at java.awt.EventQueue$3.run(EventQueue.java:703)
        at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:80)
        at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:90)
        at java.awt.EventQueue$4.run(EventQueue.java:733)
        at java.awt.EventQueue$4.run(EventQueue.java:731)
        at java.awt.EventQueue.dispatchEvent(EventQueue.java:730)
        at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:205)
        at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
        at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
        at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
        at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
        at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
It is a generic AMD 64-bit box running Arch Linux. (The distro packaged version is only ver 5.6, and in any case does not run.)
Is this sufficient info to identify the problem?
TIA
Re: ver 5.7 on Linux "Can't create graphics environment"
And how works [font=courier new]SweetHome3D[/font] script?
richardlyons
@Puybaret:
The Sweethome3D script opens only the splash screen and stops (as before, with 5.6).
Exception in thread "main" java.lang.InternalError: XXX0 profile[1]: GL3bc -> profileImpl GL4bc !!! not mapped
        at com.jogamp.opengl.GLProfile.computeProfileMap(GLProfile.java:2071)
        at com.jogamp.opengl.GLProfile.initProfilesForDeviceCritical(GLProfile.java:1924)
        at com.jogamp.opengl.GLProfile.initProfilesForDevice(GLProfile.java:1875)
        at com.jogamp.opengl.GLProfile.initProfilesForDefaultDevices(GLProfile.j3)
        at com.jogamp.opengl.GLProfile.access$000(GLProfile.java:80)
        at com.jogamp.opengl.GLProfile$1.run(GLProfile.java:230)
        at com.jogamp.opengl.GLProfile.initSingleton(GLProfile.java:216)
        at com.jogamp.opengl.GLProfile.getProfileMap(GLProfile.java:2297)
        at com.jogamp.opengl.GLProfile.get(GLProfile.java:1021)
        at com.jogamp.opengl.GLProfile.get(GLProfile.java:1050)
        at com.jogamp.opengl.GLProfile.getMaxFixedFunc(GLProfile.java:803)
        at javax.media.j3d.JoglPipeline.initialize(JoglPipeline.java:131)
        at javax.media.j3d.Pipeline.createPipeline(Pipeline.java:92)
        at javax.media.j3d.MasterControl.loadLibraries(MasterControl.java:858)
        at javax.media.j3d.VirtualUniverse.<clinit>(VirtualUniverse.java:267)
        at javax.media.j3d.GraphicsConfigTemplate3D.getBestConfiguration(GraphicTemplate3D.java:317)
        at java.awt.GraphicsDevice.getBestConfiguration(GraphicsDevice.java:207)
        at com.eteks.sweethome3d.j3d.Component3DManager.<init>(Unknown Source)
        at com.eteks.sweethome3d.j3d.Component3DManager.getInstance(Unknown Sour
        at com.eteks.sweethome3d.SweetHome3D.addComponent3DRenderingErrorObservewn Source)
        at com.eteks.sweethome3d.SweetHome3D.init(Unknown Source)
        at com.eteks.sweethome3d.SweetHome3D.main(Unknown Source)
richardlyons
SOLVED!:
I have just discovered the problem is caused by the fact I use a tiling window manager. Switching to icewm, for example, I get full 3D functionality.
yatsek
Country: Poland
Post by yatsek »
This post shows on top of Google search when looking for mentioned error - i.e:
$ sweethome3d
This was not solved neither by using freshly downloaded version of SweetHome3D nor by running
./SweetHome3D-Java3D-1_5_2
But what was VERY helpful was (found on some other place in this forum) to add:
-Dcom.eteks.sweethome3d.j3d.useOffScreen3DView=true
in script [font=courier new]SweetHome3D[/font]
Gianca_UY
Post by Gianca_UY »
$ sweethome3d
I've just registered to thank yatsek because this worked (on v6.6.2 just in case)!!
