Is it possible to draw a tiles on a bathroom walls etc?
Thanks
Draw tiles in bathroom
This topic has been viewed 7363 times and has 2 replies
peterweaver
- Member
- Country: UK
Re: Draw tiles in bathroom
Add a tile texture to the wall in room or wall dialogue. You will find several threads about this (7383, 6299 6159 + files in SourcForge 346 etc.)
There is also a guide in the documentation section, but it may just be easier and faster to use proper graphics software.
adryan_g78
- Country: Romania
Right click inside the room and select modify rooms.
Then change the wall base to a tile texture that you like. If you want all the wall to be covered with tiles, select that option from the same window.For bases you can specify the height, meaning that a 7 cm height lets you create a plinth and a 150cm height will cover your wall with texture at that height.
