My plan is getting complex and my graphic card is unable to cope. To speed things up I would like to put each level in a separate .sh3d file. This way I can work on each level faster.
The problem is then combining the different files into one to have a 3d look of the whole thing.
Copy and past in another file is not working in SH. Importing plans seems also be no option.
Anybody has some advice apart from buying a more powerful computer?
Michael
Merge two files
This topic has been viewed 3210 times and has 3 replies
Re: Merge two files
Copy / paste from a file to another one always works in Sweet Home 3D if you open the second file from the File > Open or File > Open recent items in the menu of the first file.
Re: Merge two files
Thanks, now I understand why it works when I close down and re-open the files.Copy and past in another file is not working in SH.... if you open the second file from the File > Open...
- Increase memory (in FAQ)Anybody has some advice apart from buying a more powerful computer?
- Put stuff you do not need on hidden levels.
- Un-check visible.
- Enable displaying of Model size in furniture list and purge big models.
- Use simpler models for the initial process and replace later (see SF 3D models 261, scroll down for compromises).
Re: Merge two files
Thanks! This is working indeed. Designing a passenger ship with 4 decks. Now I can furnish each deck seperatly and merge them for pictures as required. Merry Christmas.
