no texture on surface
This topic has been viewed 4758 times and has 8 replies
hi, my problem is, after applying texture on furniture when I give final render it shows the only color on the surface but not a texture.what I will do.plz help me.
- bdfd
Re: no texture on surface
Hi,hi, my problem is, after applying texture on furniture when I give final render it shows the only color on the surface but not a texture.what I will do.plz help me.
Can you show us (screenshots) a picture before and after ?
What are the parameters of rendering ?
What is the size of the texture (in pixels) ?
Probably a model from the Sketchup Warehouse. Sh*t happens with those.
Yes, most likely. Around the forum there are several threads about textures and Sketchup. It is usually possible to fix with Sketchup - making sure that textures/colours only are applied to the outer surfaces (using "Orient faces", "Reverse faces" and avoid and remove the "Two sided faces"). But on a complicated model, that can be a cumbersome process.Probably a model from the Sketchup...
In recent versions of SH3D, it is sometimes possible to remove the back surfaces that bleed through and ruin the rendering: If the offending material is listed in the material list (and not used elsewhere) it can be set to invisible. But then you need to be lucky with the model.
https://www.facebook.com/photo.php?fbid ... =3&theater
here in this link, you can see the floor there is no texture but only color.I also use texture on the walls but there is also the same problem.
What version do you use (see About dialog box)?
Would you have duplicated walls and rooms (possibly introduced after a quick copy paste), with a version of these objects textured differently? Just temporarily delete one of them to check that.
If this is not the right idea, could you share or [url=mailto:[email protected]]send me[/url] a simplified version showing the bug?
I m using 5.5 version.I did but there are the same thing happening,
So please, share or [url=mailto:[email protected]]send me[/url] a simplified version showing the bug?
I sometimes see something similar. It happens when I'm rendering a video, or even just single images multiple times (different view points, etc). Sometimes the texture is fine, but sometimes it's just grey.
Do others see this? Any ideas?
