Kompaß
This topic has been viewed 4574 times and has 2 replies
Simon_Franke
Kompaß
Post by Simon_Franke »
Hallo,
ich habe mit Google Earth die Haus-Position ermittelt.
Wie übertrage ich diese Angaben in Sweet Home 3D ?
Wie ermittele ich den Wert "Richtung nach Norden" - kann man das aus den Google Erath Angaben berechnen ?
Vielen Dank
Re: Kompaß
Compass - forgive me for replying in English, but saying my German is rusty, would be an understatement.
Google Earth: Set a pin/placemark on the location. A window will appear with latitude and longtitude. These numbers can be copied into the Compass in SH3D. Note that SH3D only uses three digits (and decimal degrees, which I think is what Google Earth does too - pay attention to the decimal separarator, you may need to change from . to , ) Google Earth does not, I think, report compass direction numerically, except the rough navigation compass in the top right corner. Click N to orient the map towards North.
OpenStreetMap: Find location, and zoom in. Lat/long will display in the url-bar on top of the window. OpenStreetMap is oriented (roughly) with North up.
So, setting the location is fairly straightforward. As for compass direction, there are a couple of options. One is to use a normal compass on site (deviation/variation may cause some inaccuracy). A more accurate orientation can be obtained from measuring the angle on a map (or a screenshot of a map with accurate North indication - map software probably best, but the Gimp/Inkscape will also let you measure accurate angles).
With some knowledge of navigation (and some navigation software and web tools) it is possible to calculate with a high level of accuracy (e.g. to calculate accurate angles to a dish antennae), but for most SH3D purposes, a rough compass angle will do (one degree equals 4 minutes in the sun rendering). SH3D does calculate the sun position for rendering pretty accurately (unsure about compensating for the Equation of time ), but that I have not checked). Using Sunlight simulation , it is possible to get a surprisingly good idea of how the sun moves around the house, when windows fall in the shade from trees buildings etc.
Simon_Franke
Re: Kompaß
Thank you very much
