any idea how to draw 3D-pipes?
This topic has been viewed 12995 times and has 10 replies
loray
Country: Germany
Post by loray »
Hi, i usually work with CAD software like Bricscad, Draftsight aso. but last week i tried Sweet Home 3D for several things. It's a great piece of software, thanks, at first. Placing, moving, rendering, really simple.
But i saw, that there are no drawing functions like 3D-pipe or something else. There is a polyline function, but only 2D if i saw that right.
Does anybody know how i could realize drawing some simple 3D-pipes like electric circuits or sanitary pipes? Do i have to import OBJ for this or are there any other ways?
Thanks for your help.
Re: any idea how to draw 3D-pipes?
As you say, there is no electricity/plumbing function. If you search the forum, e.g. for plumbing, you should find some suggestions on how different users have drawn what they need. Using cylinders being one way. Note that the current beta version with three-axis object rotation, makes it easier. ok
FDpaffie
Country: Nederland
Post by FDpaffie »
Draw 2 walls same length ,enter wall properties (Modify walls) and arc extent them 180 and other wall -180 . adjust wall thickness and hight if needed . next line up walls to a circle, I use cursor keys
And Export them to .OBJ format in 3D view ""make map; pipeline"" and put your creation in there.
Next Import your new pipe in furniture
[B-)]
Tip, if u need a pipe say 10 cm diameter make it in drawing 1 meter , later u can adjust his size ,same goose for length
Some Examples ..
Plummbing
Electrical_installation_material
loray
Country: Germany
Post by loray »
Really great, i'll try it. Thanks for your answers.
rossnet
Post by rossnet »
Hi there! I am unable to position a (furniture) cylinder based pipe through a wall? Do I need to apply a special setting to allow these objects to penetrate a wall or to be inside a wall? Thanks!
Disable magnetism in preferences pane.
You may also rotate objects (including the cylinder) since version 5.5. This may be helpful to quickly draw pipes.
rossnet
Post by rossnet »
Will give it a try, thanks a lot four your responses!
iTwo
Country: United States
Post by iTwo »
#404 has a plumbing library with horizontal and vertical sections, and junction pipes including T and Y sections.
https://sourceforge.net/p/sweethome3d/d-models/404/
iTwo
Post by iTwo »
Is there a way with this pipe / plumbing library to make a pipe with slope.
One end 8 feet, the other end 7 feet?
In the USA we slope drain pipes at 1/4 inch per 12 inches or 1:48.
