It would be nice if there are some short codes we can use to put in the dimensions of an object (furniture) in the name so it will appear in the plan when we tick the check box.
For example:
- if the dimension of the object is Width: 100cm Depth: 50cm Height: 90cm.
In the name field, if i can key in
Table: %d x %w x %h Teak
SH3D automatically displays
Table: 50 x 100 x 90 Teak
as the name of the object on the plan
Some short codes can be
%d - depth
%w - width
%h - height
%x - location X
%y - location Y
%e - elevation
%a - angle
Hope the devs will consider this!
Thanks in advance!
Using Dimensions in Name of object
This topic has been viewed 4466 times and has 0 replies
