error 40
This topic has been viewed 5486 times and has 5 replies
Country: UK
error 40
Post by Miker777 »
Does anyone know what error 40 means, seen when trying to export a file for html viewing.
thx
Re: error 40
Post by bdfd »
thx
I have already had this 2 or 3 times... [:-&]
I think your file is accessed by another user and you can not update it... [X-(]
Re: error 40
The error 40 covers errors that may happen during the export on the server (a little like if the Export to HTML5 plug-in failed). The reason suggested by bdfd is interesting and I should check how to avoid the issue he describes, but in the case of Mike777, it's another issue. The logs on the server report that it's due to a damaged .sh3d file. So please double check if the .sh3d file you submitted can be opened in Sweet Home 3D (maybe you copied it in a different file). I also made some adjustments that could fix your issue (even if I don't believe in this option), so please try again. Then if it still happens, please tell us.
Country: UK
Re: error 40
Post by Miker777 »
The file continues to open ok with Sweet home, i tried both compressed and uncompressed, managed to get it to upload eventually but on by removing 1 of the roof sections i had made with sketchup, thx for your help.
Re: error 40
Interesting... that could mean that the tool could not transform to OBJ format this roof section at DAE format. Please, try to create a simple .sh3d file with that section and export it. Then if it fails, send it to [url=mailto:[email protected]]me[/url] because that should help me to fix a potential bug.
Country: UK
Re: error 40
Post by Miker777 »
ty Emmanuel
I created a file with just those 2 roof sections in and it loaded fine, i dont think its a size issue as the ranch file is only 7'688 kb, and the roof file is just 26 it is here and the ranch is here.
Thanx in advance
