how can I add a fence wall that is about a hundred meters long? I tried to create a wall and slap a steel fence texture but it turned black on the transparent areas
something like this.
http://fenceworkshop.com/wp-content/upl ... -steel.jpg
Fence wall
This topic has been viewed 12998 times and has 6 replies
- bdfd
Re: Fence wall
You want this :how can I add a fence wall that is about a hundred meters long? I tried to create a wall and slap a steel fence texture but it turned black on the transparent areas
I got Something for you !
Follow this LINK
Download it and import this furniture in your project...
Re: Fence wall
Which is a good idea. Only, transparent textures do not work on walls, but would on a thin box (model instead of wall)... create a wall and slap a steel fence texture but it turned black on the transparent areas..
PS Model suggested by bdfd looks like a good fit, but there are also some simpler iron fences and gates in the SH3D repositories that would.
http://sweethome3d.com/searchModels.jsp?model=fence
https://sourceforge.net/p/sweethome3d/d ... h/?q=fence
Re: Fence wall
Hello guys!
I have the same question as Assasing 123.
I want to fence an area 100 meter by 200 meter.
How to add multiple fences at once? Adding them one by one is not an option
Thank you!
Thank you!
Re: Fence wall
Hi Khurgon, I suggest to have a look to this tutorial.
Re: Fence wall
You're the man!
Thank you!
Thank you!
Re: Fence wall
More likely a woman, but thanks to you
