Sweet Home 5.4 has stopped working
I am running windows 10
latest nvidia drivers and java installed
I click SH3D I get boot picture then it sits till eventually Java say not responding.
Sweet home not working anymore
This topic has been viewed 8081 times and has 6 replies
- bdfd
Re: Sweet home not working anymore
Hi,Hi,
[Moderated]
What is the version of updated java ?
Like you, I use SH3D 5.4 (exe) with java 1.8.0_54 and java3D v 1.6.0 and all is OK.
ok err,
I have java 1.8.0.121 installed, java3d not a clue as it looks like a manual install thing
Crash log in hs_err_pid*.log suggests this is a Direct3D issue:
So, according to http://docs.oracle.com/javase/7/docs/te ... flags.html
we can switch to OpenGL.
- Create empty file SweetHome3D.l4j.ini near SweetHome3D.l4j.exe
- Add "-Dsun.java2d.opengl=true" into that file.
After these steps SH3D works for me at latest Windows 10 1703.
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j sun.java2d.d3d.D3DGraphicsDevice.getDeviceCapsNative(I)I+0
j sun.java2d.d3d.D3DGraphicsDevice.access$000(I)I+1
j sun.java2d.d3d.D3DGraphicsDevice$1.run()V+8
v ~StubRoutines::call_stub
j sun.awt.windows.WToolkit.eventLoop()V+0
j sun.awt.windows.WToolkit.run()V+58
j java.lang.Thread.run()V+11
- bdfd
Hi,Crash log in hs_err_pid*.log suggests this is a Direct3D issue:Code: Select all
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code) j sun.java2d.d3d.D3DGraphicsDevice.getDeviceCapsNative(I)I+0 j sun.java2d.d3d.D3DGraphicsDevice.access$000(I)I+1 j sun.java2d.d3d.D3DGraphicsDevice$1.run()V+8 v ~StubRoutines::call_stub j sun.awt.windows.WToolkit.eventLoop()V+0 j sun.awt.windows.WToolkit.run()V+58 j java.lang.Thread.run()V+11 v ~StubRoutines::call_stub
Without effect for me ! [:(] [:((] [#-o]
same for me no differenceHi,Crash log in hs_err_pid*.log suggests this is a Direct3D issue:Code: Select all
well got it working by reloading a backup from december
How strange!!!
How strange!!!
