confused Stairs/treppe DHH needed/benötigt
This topic has been viewed 11690 times and has 9 replies
fbehrendt
Post by fbehrendt »
Hi all,
I am looking for stairs like these 2:
First one is a concrete stair with wooden steps (Betontreppe mit Holzstufen)
Second one is a wooden stair made of the same wood as the steps of the first one. The blue line is glass. (Freihe Holtztreppe)
Both stairs have 3,38m width and 1,76m and 2,55m height.
It would be great to get your help cause this is currently my biggest issue in planning our new house :)
THANKS!
Re: Stairs/treppe DHH needed/benötigt
Something like this one?
https://3dwarehouse.sketchup.com/model. ... c8942f82d7
You may have to do some adaptations
Took one of the reasonably similar draft ones and adapted to your measures. Posted in SF 3D models 414. Named materials for removal of handrails. Cutout based on your dimensions (see .sh3d file.) It might fit (if mirrored). If anyone else needs this model, it probably should be adjusted so thread/construction/risers are separated. ok
.sh3d file (with cutout/planicon) staircase_u2.sh3d
.obj file: staircase_u2.zip
Some additional changes: Three alternative cutouts, changed/corrected model with risers/handrail/balusters. All can be "removed" by setting to invisible:
staircase_u2h.sh3d
.obj file (no cutout/planicon): staircase_u2h.zip
fbehrendt
Post by fbehrendt »
Thank you very much!!
I will try these later.
Do you also have those kind of windows?
[Note from moderator: fixed the link to images. fbehrendt, please ensure these links are correct before posting your message]
Post by bdfd »
Sorry, but I don't see the last five pictures while the 2 first are OK... [:(]
The answer to your window question is yes ... and no. Yes because I do have several non rectangular windows. No, because they are unlikely to be of much use to you. Angles in my windows are adjusted exactly to what I needed and they will not scale the way you want them. E.g. if you want them wider, the top angle will be wrong. Making such windows that are of general interest is probably not doable. You could, of course search for such models, but I doubt you will find exactly what you need.
However, I made a couple of very simple ones quickly with your approximate angles (very approximate) and without any trimmings - see below.
You are likely to get a better result simply combining several windows from the standard collection. In the examples the Fixed triangle window is combined with Fixed window. The combination will give you much more freedom in scaling to correct proportions. If need be, of course, you can export a group of windows and reimport them as one window. That will make them easier to move around. Good luck. ok
Examples in SF 3d models #405 Strange windows
slashwin.sh3d
.obj files:
slashwin1.zip
slashwin2.zip
@ bdfd - yes, there is something with the image links. Not sure what. However, if you grab the link (if need be from source) you will find them. Moderator edited the first ones so they are visible. ok
Country: UK
Post by Miker777 »
Nice work okh.
fbehrendt, you might get some satisfaction from creating your own windows, a few carefully sized and positioned box's, a transparent wall, created in a separate window and imported as a window, you could have your own unique windows.
Enjoy
..satisfaction from creating your own...
Yes, of course, there is that. AOI, Blender, Sketchup, Wings3d, etc. are all well suited for such models. Still, a lot can be done with SH3D itself. Do not forget the ShapeGenerator plugin (from the plugin page). Using the shape generator with a few walls and such drawn horizontally, you can work wonders just combining basic elements. Miker777 is absolutely right. Creating your own models really is a great satisfaction. Not least because you get what you want - or approximations thereof.... ok
