Floor in home appears white when rendered
This topic has been viewed 5003 times and has 2 replies
Cyborggeffien
Post by Cyborggeffien »
I'm having a problem while I render a living/dining room inside a house. The floor appears mostly white even though there's a wooden texture on the floor. As you can see in the top image little brown specks appear on the floor.
What the floor looks like when rendering in either of the two high quality modes:
The floor will also appear like the top image even when another image texture is used or a solid color other than white is used.
What the floor texture looks like when rendering in either of the two fast modes:
Why is the floor appearing white while rendering in either of the two high quality modes? The floor's Matt/Shiny setting is set to Matt. Here is a link to the .sh3d file:
http://www.mediafire.com/file/wfutfc8s3 ... effien.zip
System specs:
  • OS: Windows 7 64 bit
    RAM: 4 GB
    Graphics Memory: 512MB NVIDIA NVS 3100M
    CPU: Intel Core i5 540M @ 2.53GHz
    Sweet home 3D version: 5.3
    Java Version: Version 8 Update 111
Country: UK
Re: Floor in home appears white when rendered
Post by Miker777 »
Hi Cyborg
Just had a quick look at the file, appears to be a floor/wall hieght issue, but you will need someone better with numbers than me to sort it.
Cyborggeffien
I found a big problem in the sh3d file. Inside the crawl space level, there was a room filling up the entire crawl space. I deleted it. The floor texture displays properly.
Here is a picture depicting the floor rendered properly:
@Miker777, I don't know what to say about your post. I don't mean to ignore you or anything.
