Hello
I would like to know how to create a wall with the same height but with different starting elevation from that of the arrival, both NOT at the floor level.
Thanks for the attention
This topic has been viewed 4441 times and has 2 replies
Re: create a wall with the same height but with different starting elevation
Not sure to understand your problem. Can't you set the heights you want on walls with the Height at start and Height at end values available in the Wall modification pane?
Hi Pincio
As far as i know, walls always start at 0 (floor hieght), could you use a box (which can be elevated) instead of a wall?
