Stairs
This topic has been viewed 10993 times and has 5 replies
Mantaray36
Country: United Kingdom
Stairs
Post by Mantaray36 »
Hi everyone. I'm new to Sweet Home 3D but loving the programme so far but I wonder if I can get some help?
I've tried to model some floating stairs but creating blocks and locking them up against the wall. The problem I'm having is that when I model the next level I can't see the stairs. Is there any way of seeing them or is there something else I should do in this instance? Thanks.
Re: Stairs
Post by bdfd »
Hi lonely,
If I understood well , you can use boxes (seen on the plan) put against a wall at the good position...
The best wil be a small drawing of you want to do. [:)]
Mantaray36
Re: Stairs
Thanks bdfd.
Creating the stairs isn't the problem but being able to see them when I add the next level up is.
Not sure how I add a photo on here but if you can give me some help I'll post it.
Re: Stairs
If the question is how to cut the ceiling/floor above, you can either draw the floor above manually, or export the staircase as .obj and re-import it checking the 'staircase' option. That way the model will make the cut-out (when reaching the ceiling).
If you need a more elaborate cut-out, you need to use the Furniture Library Editor available on the download page. You can find more about how to enter the cut-out shape in the forum or the SVG mini guide.
Re: Stairs
Post by bdfd »
I choosed 'mediafire.com' for example but you must create a account.
Upload your drawing on it and click on 'share options' to get the 'direct link' and copy-paste in the forum. [:)]
Mantaray36
Re: Stairs
okh's suggestion sorted out my problem. I had previously tried to export my stairs to an OBJ file and selected Staircase but it didn't work. I now know that the stairs have to reach exactly to the ceiling in order to make them show. Thanks for your help everyone.
