How do I delete a file?
This topic has been viewed 3177 times and has 1 replies
jjc58
Country: Northglenn, CO, United States
Post by jjc58 »
I've been playing with this program a few years now and have a lot of saved files I would like to delete. How do I delete a file from within the program? Right now, I have to first open a file in sh3d. If I want to delete it I have to note the file name, close sh3d, run a search from the Windows start screen and delete the file using Windows. This is very time consuming, and doesn't always work. I really need to be able to clean out the excess files from the program. Is there a way to do this I've missed?
tinboye
Country: Lethbridge, AB, Canada
Re: How do I delete a file?
Post by tinboye »
I could only find an option to erase the recent menu. Aside from that, you would have to do a complete search of your HD and search *.sh3d, then you could CTRL + A then Ctrl + X, then go into 1 folder where you want all the files to be located. then Ctrl + V. This will move all files selected into that folder. Note however if the filenames shares the same name, it will prompt you to either overwrite the existing file or you can choose to create a new file with (1) at the end.
