Join (or merge) 2 adjacent walls?
This topic has been viewed 6837 times and has 2 replies
CCPT
Post by CCPT »
Hi
When I draw 2 or more walls in a single process, adjacent walls are drawn with a "join" between them:
However if I draw the adjacent walls at different times they don't "join" together - and has a result if the 2 walls have different colors in 3d view we see a vertical stripe on the union off the 2 walls:
Is it possible to "merge" these 2 walls?
Thanks,
CC
Re: Join (or merge) 2 adjacent walls?
The #4 Advanced plan editing plug-in available from the SH3D SF plug-ins allows you to connect / join two selected walls (that run in the 'same' direction, when they are selected in the correct order). ok
CCPT
Post by CCPT »
Thank you - this plugin solved my issue.
