Picture imported furniture does not show in library
This topic has been viewed 3503 times and has 3 replies
When I import a furniture, I get only a white square in the library without showing the imported object. I can integrate it in my drawing, but how can I make it visible in the library, when I want to have an overview of objects.
Re: Picture imported furniture does not show in library
Does anyone recognize this problem or am I the only one? And is there a solutin for?
Try this:
Select the model in the furniture list (top-left window)
Select Modify
Click Next until you arrive at the last screen
Rotate the image of the model a bit.
Click Finish.
Select Modify
Click Finish.
it worked a couple of times, and then it didn't. But then I discovered the reason: do not click on 'finish' too soon. Simple yes, you just have to know. thank you for your answer.
