When I do right click "Run as administrator" on SweetHome3D-5.2-windows.exe, nothing happens.
So I can not use the SweetHome3D.l4j.ini file.
With SweetHome3D-5.1-windows.exe, the installation window opens.
Inability to install Sweet Home 3D 5.2 on Windows Vista
This topic has been viewed 4724 times and has 2 replies
Re: Inability to install Sweet Home 3D 5.2 on Windows Vista
I hope you'll find the reason why it doesn't work for you, just because I don't have any PC with Vista to test the installer. I tested it on Windows XP, 8.1 and 10.
But why do you need to run the installer with Run as administrator menu item?
Double-clicking does not work, I tested the right click...
I have not had any problems with the beta versions of the installer.
The SweetHome3D.l4j.ini file was useful to set preference the rendering properties. As I use the portable version instead, I should find another solution.
EnkoNyito
