Hello All
I have a curved wall. It now needs a curved window.
How can I do this?
Many thanks !
Curved window
This topic has been viewed 3365 times and has 1 replies
Re: Curved window
You should find a couple of examples in SF 3D models #295 Windows for arched walls. One of the curved windows might fit, but it really depends on the specifications of wall and window. Also, the auto-adjustment of window depth aligning it with the wall, does not work for curved walls, so windows must placed manually (without magnetism, toggles with ALT) in the curved wall adjusting the thickness of the window so it cuts correctly.
In real life, though, curved windows are not that common and quite expensive. Obviously you can also use normal windows and place them manually (as above) along the curve of the wall.
